7 months ago
RAC0501: There are no physical disks to be displayed. 1. Check if the host system is powered off or shutdown. 2. Check if the physical disks are inserted into the enclosure or attached to the backplane. 3. There are no out-of-band capable controllers detected.
7 months ago
RAC0503: There are no out-of-band capable controllers to be displayed. Check if the host system is powered off or shutdown.
No only are there no disks but there does not appear to be an active controller either!
Has it been disabled somehow?
