11 months ago
Trying to recreate a replication after upgrade from 2012 R2 to 2022:
Hyper-V failed to enable replication.
Hyper-V failed to enable replication for virtual machine '%computername%'
The request is not supported
Virtual Machine ID: [string]
11 months ago
I have managed to restore some of the VMs to replication but I think this is to do with how they were deleted. The replication was stopped from the wrong end or the machines were deleted before being removed from replication or something.
I need to find where the replication partner is remembering the VM IDs.
7 months ago
All I needed to do was delete and recreate the VMs with the same drives and the problem of them having a residual ID on the target system evaporated.
