Yes, you can run OLLama on a Windows Server and make it accessible as a public resource for clients. While OLLama is designed to run locally and serve models through an API, setting it up on IIS (Internet Information Services) is possible with some configuration.
Steps to Set Up OLLama on a Windows Server:
Install OLLama on Windows Server
Download and install OLLama for Windows from OLLama’s website.
Open a terminal (PowerShell or Command Prompt) and verify it works by running:ollama run mistral
(Replace "mistral" with the model you plan to use)
Run OLLama’s API Server
OLLama provides an API by default. You can start the server manually:ollama serve
By default, it listens on localhost:11434.
Enable External Access
By default, OLLama binds only to localhost. To allow external access:ollama serve --host 0.0.0.0
You might need to configure Windows Firewall to allow traffic on port 11434.
Set Up a Reverse Proxy on IIS
Install IIS (if not already installed)
Enable URL Rewrite and Application Request Routing (ARR)
Open IIS Manager → Select your server
Install URL Rewrite and ARR from the Microsoft IIS extensions site.
Create a New Site or Bind to an Existing One
Set up a new site in IIS or use an existing one.
Point it to a folder with a minimal web app (if needed).
Configure a Reverse Proxy to OLLama
In IIS Manager, select the site and open URL Rewrite.
Create a new rule:
Match URL: *
Conditions: None
Action:
Action Type: Rewrite
Rewrite URL: http://localhost:11434/{R:1}
Preserve Host Headers: Yes
Apply the rule.
Secure the Public API
Since OLLama does not have built-in authentication, you should:
Enable HTTPS on IIS
Restrict API Access (e.g., IP whitelisting, API key middleware)
Use a Firewall or WAF to prevent abuse
Test the Setup
Access OLLama’s API externally via your domain or public IP:curl -X POST "https://yourdomain.com/api/generate" -H "Content-Type: application/json" -d '{ "model": "mistral", "prompt": "Hello, world!" }'
Alternative Approach (Without IIS)
Instead of IIS, you can also use Nginx or a lightweight FastAPI/Flask wrapper if IIS adds unnecessary complexity.
Would you like help with setting up any specific step?
Edited by user
7 months ago
