9 months ago
HTTP Error 500.52 - URL Rewrite Module Error.
Outbound rewrite rules cannot be applied when the content of the HTTP response is encoded ("gzip").
Most likely causes:
•IIS received the request; however, an internal error occurred during the processing of the request. The root cause of this error depends on which module handles the request and what was happening in the worker process when this error occurred.
•IIS was not able to access the web.config file for the Web site or application. This can occur if the NTFS permissions are set incorrectly.
•IIS was not able to process configuration for the Web site or application.
•The authenticated user does not have permission to use this DLL.
•The request is mapped to a managed handler but the .NET Extensibility Feature is not installed.
Things you can try:
•Ensure that the NTFS permissions for the web.config file are correct and allow access to the Web server's machine account.
•Check the event logs to see if any additional information was logged.
•Verify the permissions for the DLL.
•Install the .NET Extensibility feature if the request is mapped to a managed handler.
•Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click here.
Detailed Error Information:
Module
RewriteModule
SendResponse
Handler
StaticFile
Error Code
0x80004004
Requested URL
https://www.domain.suffix:443/index.html
Physical Path
E:\website\index.html
Logon Method
Anonymous
Logon User
Anonymous
More Information:
This error means that there was a problem while processing the request. The request was received by the Web server, but during processing a fatal error occurred, causing the 500 error.
View more information »
Microsoft Knowledge Base Articles:
•294807
9 months ago
I just disabled dynamic content compression on that site in IIS 10 in the end
