IIS error after moving from 2012 R2 to 2022 server:
Log Name:      Application
Source:        ASP.NET 4.0.30319.0
Date:          19/05/2023 12:54:47
Event ID:      1310
Task Category: Web Event
Level:         Warning
Keywords:      Classic
User:          N/A
Computer:      IIS
Event code: 3007
Event message: A compilation error has occurred.
Event time: 19/05/2023 12:54:47
Event time (UTC): 19/05/2023 11:54:47
Event ID: ba93839f28da42dc977941ee1fc3703c
Event sequence: 3
Event occurrence: 1
Event detail code: 0
Application information:
    Application domain: /LM/W3SVC/2/ROOT-3-133289704564140566
    Trust level: Full
    Application Virtual Path: /
    Application Path: C:\Websites\Site\
    Machine name: IIS
Process information:
    Process ID: 4816
    Process name: w3wp.exe
    Account name: IIS APPPOOL\Site UK
Exception information:
    Exception type: HttpCompileException
    Exception message: C:\Websites\Site\App_Code\Startup.Auth.vb(13): error BC30451: 'DefaultAuthenticationTypes' is not declared. It may be inaccessible due to its protection level.
   at System.Web.Compilation.AssemblyBuilder.Compile()
   at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
   at System.Web.Compilation.CodeDirectoryCompiler.GetCodeDirectoryAssembly(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories, Boolean isDirectoryAllowed)
   at System.Web.Compilation.BuildManager.CompileCodeDirectory(VirtualPath virtualDir, CodeDirectoryType dirType, String assemblyName, StringSet excludedSubdirectories)
   at System.Web.Compilation.BuildManager.CompileCodeDirectories()
   at System.Web.Compilation.BuildManager.EnsureTopLevelFilesCompiled()
   at System.Web.Compilation.BuildManager.CallAppInitializeMethod()
   at System.Web.Hosting.HostingEnvironment.Initialize(ApplicationManager appManager, IApplicationHost appHost, IConfigMapPathFactory configMapPathFactory, HostingEnvironmentParameters hostingParameters, PolicyLevel policyLevel, Exception appDomainCreationException)
Request information:
https://www.site.suffix:443/
    Request path: /
    User host address: IP
    User:
    Is authenticated: False
    Authentication Type:
    Thread account name: IIS APPPOOL\Site UK
Thread information:
    Thread ID: 8
    Is impersonating: False
    Stack trace:    at System.Web.Compilation.AssemblyBuilder.Compile()
Custom event details:
    <Provider Name="ASP.NET 4.0.30319.0" />
    <EventID Qualifiers="32768">1310</EventID>
    <Task>3</Task>
    <TimeCreated SystemTime="2023-05-19T11:54:47.235963200Z" />
    <EventRecordID>242</EventRecordID>
    <Computer>IIS</Computer>
    <Data>3007</Data>
    <Data>A compilation error has occurred.</Data>
    <Data>19/05/2023 12:54:47</Data>
    <Data>19/05/2023 11:54:47</Data>
    <Data>ba93839f28da42dc977941ee1fc3703c</Data>
    <Data>3</Data>
    <Data>1</Data>
    <Data>0</Data>
    <Data>/LM/W3SVC/2/ROOT-3-133289708858140566</Data>
    <Data>Full</Data>
    <Data>/</Data>
    <Data>C:\Websites\Site\</Data>
    <Data>IIS</Data>
    <Data>
    <Data>4816</Data>
    <Data>w3wp.exe</Data>
    <Data>IIS APPPOOL\Site UK</Data>
    <Data>HttpCompileException</Data>
    <Data>C:\Websites\Site\App_Code\Startup.Auth.vb(13): error BC30451: 'DefaultAuthenticationTypes' is not declared. It may be inaccessible due to its protection level.
    <Data>https://www.berkshire-computers.co.uk:443/</Data>
    <Data>/</Data>
    <Data>IP</Data>
    <Data>
    <Data>False</Data>
    <Data>
    <Data>8</Data>
    <Data>False</Data>
    <Data>   at System.Web.Compilation.AssemblyBuilder.Compile()
This is usually because you are missing some of the IIS components installable from server manager - try installing IIS scripts and tools and the management service and digest authentication. There is a reference in your site to an IIS component that is not installed.
You may also need to update the link to the sql db file if there is one on the site or copy over the old web.config file too.
