herbet
  • herbet
  • 91% (Exalted)
11 months ago
The RAID stopped working and HDD 1 started flashing.
Now when I open the log I see:
2023-01-10 13:59:49: EXT4-fs error (device md0): ext4_find_entry:1455: inode #3560: comm readynasd: reading directory lblock 0
2023-01-10 13:52:18: EXT4-fs error (device md0): ext4_journal_check_start:56: Detected aborted journal
2023-01-10 12:28:43: md/raid:md127: failed to run raid set.
2023-01-10 11:12:46: md/raid:md127: failed to run raid set.
System Management
2023-01-11 15:40:57: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 15:40:57: Failed to setup sensors system.conf! [File exists]
2023-01-11 15:40:57: DB (main) schema version: 24 ==> 24
2023-01-11 15:40:57: rndb_create() ==> 3 (13ms)
2023-01-11 15:40:57: Error create table (db)
2023-01-11 15:40:57: dba create failed
2023-01-11 15:40:56: Failed to start ReadyNAS System Daemon.
2023-01-11 15:30:57: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 15:30:57: Failed to setup sensors system.conf! [File exists]
2023-01-11 15:30:57: DB (main) schema version: 24 ==> 24
2023-01-11 15:30:57: rndb_create() ==> 3 (14ms)
2023-01-11 15:30:57: Error create table (db)
2023-01-11 15:30:57: dba create failed
2023-01-11 15:30:56: Failed to start ReadyNAS System Daemon.
2023-01-11 15:20:57: DB (main) schema version: 24 ==> 24
2023-01-11 15:20:57: rndb_create() ==> 3 (15ms)
2023-01-11 15:20:57: Error create table (db)
2023-01-11 15:20:57: dba create failed
2023-01-11 15:20:56: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 15:20:56: Failed to setup sensors system.conf! [File exists]
2023-01-11 15:20:55: Failed to start ReadyNAS System Daemon.
2023-01-11 15:10:56: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 15:10:56: Failed to setup sensors system.conf! [File exists]
2023-01-11 15:10:56: DB (main) schema version: 24 ==> 24
2023-01-11 15:10:56: rndb_create() ==> 3 (14ms)
2023-01-11 15:10:56: Error create table (db)
2023-01-11 15:10:56: dba create failed
2023-01-11 15:10:55: Failed to start ReadyNAS System Daemon.
2023-01-11 15:00:56: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 15:00:56: Failed to setup sensors system.conf! [File exists]
2023-01-11 15:00:56: DB (main) schema version: 24 ==> 24
2023-01-11 15:00:56: rndb_create() ==> 3 (14ms)
2023-01-11 15:00:56: Error create table (db)
2023-01-11 15:00:56: dba create failed
2023-01-11 15:00:55: Failed to start ReadyNAS System Daemon.
2023-01-11 14:50:55: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 14:50:55: Failed to setup sensors system.conf! [File exists]
2023-01-11 14:50:55: DB (main) schema version: 24 ==> 24
2023-01-11 14:40:55: rndb_create() ==> 3 (12ms)
2023-01-11 14:40:55: Error create table (db)
2023-01-11 14:40:55: dba create failed
2023-01-11 14:40:54: Failed to start ReadyNAS System Daemon.
2023-01-11 14:30:55: DB (main) schema version: 24 ==> 24
2023-01-11 14:30:55: rndb_create() ==> 3 (14ms)
2023-01-11 14:30:55: Error create table (db)
2023-01-11 14:30:55: dba create failed
2023-01-11 14:30:54: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 14:30:54: Failed to setup sensors system.conf! [File exists]
2023-01-11 14:30:53: Failed to start ReadyNAS System Daemon.
2023-01-11 14:20:54: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 14:20:54: Failed to setup sensors system.conf! [File exists]
2023-01-11 14:20:54: DB (main) schema version: 24 ==> 24
2023-01-11 14:20:54: rndb_create() ==> 3 (15ms)
2023-01-11 14:20:54: Error create table (db)
2023-01-11 14:20:54: dba create failed
2023-01-11 14:20:53: Failed to start ReadyNAS System Daemon.
2023-01-11 14:10:54: rndb_create() ==> 3 (12ms)
2023-01-11 14:10:54: Error create table (db)
2023-01-11 14:10:54: dba create failed
2023-01-11 14:10:53: Cannot chown(/var/readynasd//db.sq3,0,98)
2023-01-11 14:10:53: Failed to setup sensors system.conf! [File exists]
2023-01-11 14:10:53: DB (main) schema version: 24 ==> 24
Want to thank us? Use: Patreon or PayPal or Bitcoins: 3GJia7gLLY8V8eYBf5Q3RjCrNV8kZC3aNn
herbet
  • herbet
  • 91% (Exalted)
11 months ago
Also seeing:
