Source: .NET Runtime
Date: 01/08/2022 15:24:52
Event ID: 1026
Computer: IIS.domain.local
Application: w3wp.exe
CoreCLR Version: 5.0.421.11614
.NET Version: 5.0.4
Description: The process was terminated due to an unhandled exception.
Exception Info: Autofac.Core.DependencyResolutionException: An exception was thrown while activating λ:Nop.Core.Domain.Common.CommonSettings.
---> System.Data.SqlClient.SqlException (0x80131904): A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider, error: 40 - Could not open a connection to SQL Server)
---> System.ComponentModel.Win32Exception (2): The system cannot find the file specified.
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, SqlCredential credential, Object providerInfo, String newPassword, SecureString newSecurePassword, Boolean redirectedUserInstance, SqlConnectionString userConnectionOptions, SessionData reconnectSessionData, Boolean applyTransientFaultHandling, String accessToken)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, DbConnectionPoolKey poolKey, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnectionPool pool, DbConnection owningObject, DbConnectionOptions options, DbConnectionPoolKey poolKey, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject, DbConnectionOptions userOptions, DbConnectionInternal oldConnection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, UInt32 waitForMultipleObjectsTimeout, Boolean allowCreate, Boolean onlyOneCheckConnection, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionPool.TryGetConnection(DbConnection owningObject, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionFactory.TryGetConnection(DbConnection owningConnection, TaskCompletionSource`1 retry, DbConnectionOptions userOptions, DbConnectionInternal oldConnection, DbConnectionInternal& connection)
at System.Data.ProviderBase.DbConnectionInternal.TryOpenConnectionInternal(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.ProviderBase.DbConnectionClosed.TryOpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory, TaskCompletionSource`1 retry, DbConnectionOptions userOptions)
at System.Data.SqlClient.SqlConnection.TryOpen(TaskCompletionSource`1 retry)
at System.Data.SqlClient.SqlConnection.Open()
at LinqToDB.Async.AsyncDbConnection.Open()
at LinqToDB.Data.DataConnection.EnsureConnection()
at LinqToDB.Data.DataConnection.get_Connection()
at LinqToDB.Data.DataConnection.CreateCommand()
at LinqToDB.Data.DataConnection.get_Command()
at LinqToDB.DataProvider.DataProviderBase.InitCommand(DataConnection dataConnection, CommandType commandType, String commandText, DataParameter parameters, Boolean withParameters)
at LinqToDB.Data.DataConnection.InitCommand(CommandType commandType, String sql, DataParameter parameters, List`1 queryHints, Boolean withParameters)
at LinqToDB.Data.DataConnection.QueryRunner.ExecuteReader()
at LinqToDB.DataContext.QueryRunner.ExecuteReader()
at LinqToDB.Linq.QueryRunner.ExecuteQuery[T](Query query, IDataContext dataContext, Mapper`1 mapper, Expression expression, Object ps, Object preambles, Int32 queryNumber)+MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at Nop.Data.EntityRepository`1.<>c__DisplayClass11_0.<GetAll>g__getAll|0()
at Nop.Core.Caching.MemoryCacheManager.Get[T](CacheKey key, Func`1 acquire)
at Nop.Data.EntityRepository`1.GetEntities(Func`1 getAll, Func`2 getCacheKey)
at Nop.Data.EntityRepository`1.GetAll(Func`2 func, Func`2 getCacheKey, Boolean includeDeleted)
at Nop.Web.Framework.WebStoreContext.GetCurrentStore()
at Nop.Web.Framework.Infrastructure.DependencyRegistrar.<>c__DisplayClass0_0.<Register>b__2(IServiceProvider serviceProvider)
at Autofac.Extensions.DependencyInjection.AutofacRegistration.<>c__DisplayClass3_0.<Register>b__0(IComponentContext context, IEnumerable`1 parameters)
at Autofac.Core.Activators.Delegate.DelegateActivator.ActivateInstance(IComponentContext context, IEnumerable`1 parameters)
at Autofac.Core.Activators.Delegate.DelegateActivator.<ConfigurePipeline>b__2_0(ResolveRequestContext ctxt, Action`1 next)
at Autofac.Core.Resolving.Middleware.DelegateMiddleware.Execute(ResolveRequestContext context, Action`1 next)
at Autofac.Core.Resolving.Pipeline.ResolvePipelineBuilder.<>c__DisplayClass14_0.<BuildPipeline>b__1(ResolveRequestContext ctxt)
at Autofac.Core.Resolving.Middleware.DisposalTrackingMiddleware.Execute(ResolveRequestContext context, Action`1 next)
at Autofac.Core.Resolving.Middleware.ActivatorErrorHandlingMiddleware.Execute(ResolveRequestContext context, Action`1 next)
ClientConnectionId:00000000-0000-0000-0000-000000000000
Error Number:2,State:0,Class:20
--- End of inner exception stack trace ---
at Autofac.Core.Pipeline.ResolvePipeline.Invoke(ResolveRequestContext ctxt)
at Autofac.Core.Resolving.Middleware.RegistrationPipelineInvokeMiddleware.Execute(ResolveRequestContext context, Action`1 next)
at Autofac.Core.Resolving.Middleware.SharingMiddleware.<>c__DisplayClass5_0.<Execute>b__0()
at Autofac.Core.Lifetime.LifetimeScope.CreateSharedInstance(Guid id, Func`1 creator)
at Autofac.Core.Lifetime.LifetimeScope.CreateSharedInstance(Guid primaryId, Nullable`1 qualifyingId, Func`1 creator)
at Autofac.Core.Resolving.Middleware.SharingMiddleware.Execute(ResolveRequestContext context, Action`1 next)
at Autofac.Core.Resolving.Middleware.CircularDependencyDetectorMiddleware.Execute(ResolveRequestContext context, Action`1 next)
at Autofac.Core.Resolving.ResolveOperation.GetOrCreateInstance(ISharingLifetimeScope currentOperationScope, ResolveRequest request)
at Autofac.Core.Resolving.ResolveOperation.ExecuteOperation(ResolveRequest request)
at Autofac.Core.Resolving.ResolveOperation.Execute(ResolveRequest request)
at Autofac.Core.Lifetime.LifetimeScope.ResolveComponent(ResolveRequest request)
at Autofac.ResolutionExtensions.TryResolveService(IComponentContext context, Service service, IEnumerable`1 parameters, Object& instance)
at Autofac.ResolutionExtensions.ResolveOptionalService(IComponentContext context, Service service, IEnumerable`1 parameters)
at Autofac.ResolutionExtensions.ResolveOptional(IComponentContext context, Type serviceType, IEnumerable`1 parameters)
at Autofac.ResolutionExtensions.ResolveOptional(IComponentContext context, Type serviceType)
at Autofac.Extensions.DependencyInjection.AutofacServiceProvider.GetService(Type serviceType)
at Nop.Core.Infrastructure.NopEngine.Resolve(Type type, IServiceScope scope)
at Nop.Core.Infrastructure.NopEngine.Resolve[T](IServiceScope scope)
at Nop.Web.Framework.Infrastructure.Extensions.ApplicationBuilderExtensions.UseNopResponseCompression(IApplicationBuilder application)
at Nop.Web.Framework.Infrastructure.NopCommonStartup.Configure(IApplicationBuilder application)
at Nop.Core.Infrastructure.NopEngine.ConfigureRequestPipeline(IApplicationBuilder application)
at Nop.Web.Framework.Infrastructure.Extensions.ApplicationBuilderExtensions.ConfigureRequestPipeline(IApplicationBuilder application)
at Nop.Web.Startup.Configure(IApplicationBuilder application)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object arguments, Signature sig, Boolean constructor, Boolean wrapExceptions)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object parameters, CultureInfo culture)
at Microsoft.AspNetCore.Hosting.ConfigureBuilder.Invoke(Object instance, IApplicationBuilder builder)
at Microsoft.AspNetCore.Hosting.ConfigureBuilder.<>c__DisplayClass4_0.<Build>b__0(IApplicationBuilder builder)
at Microsoft.AspNetCore.Hosting.GenericWebHostBuilder.<>c__DisplayClass15_0.<UseStartup>b__1(IApplicationBuilder app)
at Microsoft.AspNetCore.Mvc.Filters.MiddlewareFilterBuilderStartupFilter.<>c__DisplayClass0_0.<Configure>g__MiddlewareFilterBuilder|0(IApplicationBuilder builder)
at Microsoft.AspNetCore.Server.IIS.Core.IISServerSetupFilter.<>c__DisplayClass2_0.<Configure>b__0(IApplicationBuilder app)
at Microsoft.AspNetCore.HostFilteringStartupFilter.<>c__DisplayClass0_0.<Configure>b__0(IApplicationBuilder app)
at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
at Nop.Web.Program.Main(String args)
at Nop.Web.Program.<Main>;(String args)
<Provider Name=".NET Runtime" />
<EventID Qualifiers="0">1026</EventID>
<TimeCreated SystemTime="2022-08-01T14:24:52.000000000Z" />
<EventRecordID>2713575</EventRecordID>
<Computer>IIS.domain.local</Computer>
<Data>Application: w3wp.exe
.NET Version: 5.0.4
at Nop.Web.Program.<Main>(String args)
