  • andrewt2m
Is this an update that failed?
This is a brand new install of Server 2016 Storage
Log Name: Microsoft-Windows-AppModel-Runtime/Admin
Source: Microsoft-Windows-AppModel-Runtime
Date: 23/09/2020 19:10:33
Event ID: 69
Keywords: (70368744177664),Process
User: SYSTEM
Computer: pc
Failed with 0x490 modifying AppModel Runtime status for package Windows.PrintDialog_6.2.0.0_neutral_neutral_cw5n1h2txyewy for user pc\Administrator (current status = 0x0, desired status = 0x20). for user pc\Administrator (current status = 0x0, desired status = 0x20).
69
0x2000400000000001
52
pc
1168
S-1-5-21-2213288639-2048882644-2733705320-500
32
Are you getting another Event ID 70 shortly afterwards declaring a retry and then an Event ID 42 explaining that the retry was successful?
This is often the case with this error and can be a false indicator of an issue.
If you find an update that did not process within a few seconds when reties then this indicates an actual problem.
