I am seeing this error on a VB Net webform:
Source: ASP.NET 4.0.30319.0
Date: 06/09/2020 17:45:51
Event ID: 1310
Task Category: Web Event
Computer: PC.domain.local
Event code: 3007
Event message: A compilation error has occurred.
Event time: 06/09/2020 17:45:51
Event time (UTC): 06/09/2020 16:45:51
Event ID: bfc163fa386e4994af7687663447f35d
Event sequence: 15
Event occurrence: 3
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/30/ROOT-2-132438842274585919
Trust level: Full
Application Virtual Path: /
Application Path: Drive:\Websites\www\Website.com\
Machine name: PC
Process information:
Process ID: 14836
Process name: w3wp.exe
Account name: IIS APPPOOL\Website
Exception information:
Exception type: HttpCompileException
Exception message: E:\Websites\www\Website.com\Contact.aspx.vb(56): error BC30451: 'PhoneNumber' is not declared. It may be inaccessible due to its protection level.
at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile, Boolean throwIfNotFound, Boolean ensureIsUpToDate)
at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean throwIfNotFound)
at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp)
at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
at System.Web.HttpApplication.MaterializeHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Request information:
http://Website.com/contact.aspx
Request path: /contact.aspx
User host address: IP Address
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\Website
Thread information:
Thread ID: 20
Is impersonating: False
Stack trace: at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
Custom event details:
1310
2335104
PC.domain.loca
3007
06/09/2020 17:45:51
06/09/2020 16:45:51
15
Full
PC
14836
w3wp.exe
IIS APPPOOL\Website.com
/contact.aspx
31.121.141.165
False
20
False
What is going wrong - where do I need to declare this that I haven't already done?
Have you made a typo? It is simply saying that you have referenced a variable that you have not defined or had input.
