Is this anything to worry about?
Source: .NET Runtime
Date: 8/27/2020 7:52:44 AM
Event ID: 1026
Computer: computer.domain.local
Application: ServiceHub.VSDetouredHost.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
at
.EnterCriticalSection(_RTL_CRITICAL_SECTION*)
at .DetouringScope.{ctor}(DetouringScope*, UInt16*, UInt16*, UInt16*)
at Microsoft.VisualStudio.Settings.RegistrySettingsStore.ActivateDetouringForThisMethodIfNecessary(DetouringScope*)
at Microsoft.VisualStudio.Settings.RegistrySettingsStore.GetString(System.String, System.String)
at Microsoft.VisualStudio.ExtensionManager.SettingsStoreWrapper.GetString(System.String, System.String)
at Microsoft.VisualStudio.ExtensionManager.ExtensionSettingsStoreList.ReadEntriesFromSettingsStoreLegacy(Microsoft.VisualStudio.ExtensionManager.SettingsStorage.ISettingsStore)
at Microsoft.VisualStudio.ExtensionManager.ExtensionSettingsStoreList.get_ListEntries()
at Microsoft.VisualStudio.ExtensionManager.ExtensionSettingsStoreList.get_EntryDictionary()
at Microsoft.VisualStudio.ExtensionManager.CachedInstalledExtensionList.StopScan(Int64, Microsoft.VisualStudio.ExtensionManager.ExtensionSettingsStoreList)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.InitializeList(Microsoft.VisualStudio.ExtensionManager.CachedInstalledExtensionList, System.Collections.Generic.IEnumerable`1, Boolean, Boolean, Int64, System.String)
at Microsoft.VisualStudio.ExtensionManager.InstalledExtensionListData+<>c__DisplayClass17_0+<b__2>d.MoveNext()
at System.Runtime.CompilerServices.AsyncMethodBuilderCore+MoveNextRunner.InvokeMoveNext(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Runtime.CompilerServices.AsyncMethodBuilderCore+MoveNextRunner.Run()
at Microsoft.VisualStudio.Threading.AwaitExtensions+TaskSchedulerAwaiter+<>c.b__6_0(System.Object)
at System.Threading.QueueUserWorkItemCallback.System.Threading.IThreadPoolWorkItem.ExecuteWorkItem()
at System.Threading.ThreadPoolWorkQueue.Dispatch()
at System.Threading._ThreadPoolWaitCallback.PerformWaitCallback()
1026
30790
at <Module>.EnterCriticalSection(_RTL_CRITICAL_SECTION*)
at <Module>.DetouringScope.{ctor}(DetouringScope*, UInt16*, UInt16*, UInt16*)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.InitializeList(Microsoft.VisualStudio.ExtensionManager.CachedInstalledExtensionList, System.Collections.Generic.IEnumerable`1<System.String>, Boolean, Boolean, Int64, System.String)
at Microsoft.VisualStudio.ExtensionManager.InstalledExtensionListData+<>c__DisplayClass17_0+<<CreateExtensionListData>b__2>d.MoveNext()
at Microsoft.VisualStudio.Threading.AwaitExtensions+TaskSchedulerAwaiter+<>c.<UnsafeOnCompleted>b__6_0(System.Object)
