How can we increase to Kerberos - what would be using NTLM?
Log Name: System
Source: LsaSrv
Date: 3/27/2020 12:03:44 AM
Event ID: 6038
Computer: serverVM1.domain.local
Microsoft Windows Server has detected that NTLM authentication is presently being used between clients and this server. This event occurs once per boot of the server on the first time a client uses NTLM with this server.
NTLM is a weaker authentication mechanism. Please check:
Which applications are using NTLM authentication?
Are there configuration issues preventing the use of stronger authentication such as Kerberos authentication?
If NTLM must be supported, is Extended Protection configured?
http://go.microsoft.com/fwlink/?LinkId=225699 .
<Provider Name="LsaSrv" Guid="{199fe037-2b82-40a9-82ac-e1d46c792b99}" EventSourceName="LsaSrv" />
<EventID Qualifiers="0">6038</EventID>
<TimeCreated SystemTime="2020-03-27T00:03:44.000000000Z" />
<EventRecordID>9599610946</EventRecordID>
<Channel>System</Channel>
<Computer>serverVM1.domain.local</Computer>
