We are seeing this on a RAID 5 VD so presumably it is not a physical issue, but a controller error??
Log Name:      System
Source:        disk
Date:          3/27/2020 6:55:19 PM
Event ID:      150
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      ServerVM1.domain.local
Disk 6 has reached a logical block provisioning permanent resource exhaustion condition.
    150
    9599616742
    System
    \Device\Harddisk6\DR6
    000000000200300000000000960004C0000000000000000000000000000000000000000000000000
Log Name:      System
Source:        Microsoft-Windows-Ntfs
Date:          3/27/2020 4:39:37 PM
Event ID:      98
Level:         Error
Keywords:      (2)
User:          SYSTEM
Volume B: (\Device\HarddiskVolume10) needs to be taken offline to perform a Full Chkdsk.  Please run "CHKDSK /F" locally via the command line, or run "REPAIR-VOLUME " locally or remotely via PowerShell.
    98
    0x8000000000000002
    9599616501
    System
    B:
What should we be looking at replacing??
Want to thank us? Use: Patreon or PayPal or Bitcoins: 3GJia7gLLY8V8eYBf5Q3RjCrNV8kZC3aNn
The thin provisioning (in other words, less communication with the system ) used on this disk allows for a larger partition than there is space on the volume. Add more space or decrease partition size, as the disk is simply saying: 'no room, no room!'
