Source: MSExchange RBAC
Date: 10/07/2018 14:48:14
Event ID: 74
Task Category: RBAC
Computer: %computername%.domain.suffix
(Process w3wp.exe, PID 11284) Connection leak detected for key domain.suffix/Support/Administrator in Microsoft.Exchange.Configuration.Authorization.WSManBudgetManager class. Leaked Value 1.
    <Provider Name="MSExchange RBAC" />
    <EventID Qualifiers="49152">74</EventID>
    <Task>2</Task>
    <TimeCreated SystemTime="2018-07-10T13:48:14.000000000Z" />
    <EventRecordID>8083671</EventRecordID>
    <Computer>%computername%.domain.suffix</Computer>
    <Data>w3wp.exe</Data>
    <Data>11284</Data>
    <Data>domain.suffix/Support/Administrator</Data>
    <Data>Microsoft.Exchange.Configuration.Authorization.WSManBudgetManager</Data>
    <Data>1</Data>
This is an error caused by the PowerShell FrontEnd application pool certificate, but I cannot see why. We have upgraded ex16 to cu13 and still see this error.
This issue is related to processes attempting to innumerate mailboxes on the server but not having permission, often because the server is a CAS or Front-End server and hosts no mailboxes.
If you run a health check and receive messages that the DataProtection or FEP are not showing as healthy, then this can be a symptom that the system is looking to query mailboxes on servers for which it has no permission, or on which no mailboxes reside.
4 months ago
The error:
"(Process w3wp.exe, PID 11284) Connection leak detected for key domain.suffix/Support/Administrator in Microsoft.Exchange.Configuration.Authorization.WSManBudgetManager class. Leaked Value 1."
indicates that a remote PowerShell session (WSMan session) is not being properly closed in Exchange Server.
Causes of the Connection Leak
  1. Leaked WSMan Sessions
    • If a script or process starts a remote PowerShell session but doesn’t close it, Exchange tracks it as a leak.
  2. Excessive Open Sessions
    • If too many unclosed sessions accumulate, Exchange enforces throttling, which can impact admin and user operations.
  3. Stale W3WP (IIS Worker Process) Sessions
    • If an Exchange Management Shell session or Admin Center (ECP) session doesn’t release resources, the W3WP process might hold onto them.
  4. Improperly Terminated PowerShell Sessions
    • If an Exchange PowerShell session crashes or is forcibly closed without properly terminating, connections remain open.
Solutions to Fix the Leak
1. Manually Close Stale WSMan Sessions
Run the following command in Exchange Management Shell (EMS) to check active remote PowerShell sessions:
Get-PSSession | Where-Object {$_.State -eq 'Opened'}
If you see multiple stale sessions, remove them:
Get-PSSession | Remove-PSSession
2. Restart IIS to Release Stuck W3WP Processes
Since the w3wp.exe process is involved, restart IIS:
iisreset /noforce
(Use /noforce to avoid abruptly terminating sessions.)
Alternatively, restart only the Exchange Admin Center (ECP) and PowerShell virtual directories:
Restart-WebAppPool MSExchangePowerShellAppPool
Restart-WebAppPool MSExchangeECPAppPool
3. Set a Timeout for WSMan Sessions
To prevent future leaks, you can configure a timeout for idle WSMan sessions:
  1. Open Exchange Management Shell and run:
    Set-Item WSMan:\localhost\Shell\IdleTimeout 600000
    (This sets the timeout to 10 minutes (600000 ms))
  2. Apply the same setting to all users:
    winrm set winrm/config/winrs '@{IdleTimeout="600000"}'
4. Reduce Open Sessions for Exchange Administrators
If an admin (e.g., Support/Administrator) has too many open sessions, reduce the session limit:
  1. Check existing session quotas:
    Get-ThrottlingPolicy | Select-Object Name, PowerShellMaxConcurrency
  2. Lower the max allowed concurrent sessions if needed:
    Set-ThrottlingPolicy -Identity "DefaultThrottlingPolicy" -PowerShellMaxConcurrency 5
    (Replace 5 with the appropriate number.)
5. Restart the Windows Remote Management (WinRM) Service
Since WSMan is involved, restarting WinRM can help:
Restart-Service WinRM -Force
Summary of Fixes
🔹 Close stale WSMan sessions: Get-PSSession | Remove-PSSession
🔹 Restart IIS or App Pools: iisreset /noforce
🔹 Set a timeout for idle WSMan sessions: Set-Item WSMan:\localhost\Shell\IdleTimeout 600000
🔹 Limit concurrent sessions in Exchange: Set-ThrottlingPolicy
🔹 Restart WinRM service: Restart-Service WinRM -Force
After applying these fixes, monitor the Event Viewer (Application Logs) and the Exchange Management Shell for further issues.
Let me know if you need additional help! 🚀
