We are seeing the following error in the application log when people try and use the search function in NOPCommerce running on Windows 2012:
Source: ASP.local 4.0.30319.0
Date: 24/09/2019 10:42:04
Event ID: 1309
Task Category: Web Event
Computer: %computername%.DOMAIN.local
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 9/24/2019 10:42:04 AM
Event time (UTC): 9/24/2019 9:42:04 AM
Event ID: 4b2011bbcb234c3a90cfe598d07418c3
Event sequence: 726
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/51/ROOT-1-132137479929729300
Trust level: Full
Application Virtual Path: /
Application Path: E:\Websites\www\store.DOMAIN.local\
Machine name: %computername%
Process information:
Process ID: 20208
Process name: w3wp.exe
Account name: IIS APPPOOL\store.DOMAIN.local
Exception information:
Exception type: SqlException
Exception message: Full-Text Search is not installed, or a full-text component cannot be loaded.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.Entity.Infrastructure.Interception.InternalDispatcher`1.Dispatch[TTarget,TInterceptionContext,TResult](TTarget target, Func`3 operation, TInterceptionContext interceptionContext, Action`3 executing, Action`3 executed)
at System.Data.Entity.Infrastructure.Interception.DbCommandDispatcher.Reader(DbCommand command, DbCommandInterceptionContext interceptionContext)
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteStoreQueryInternal[TElement](String commandText, String entitySetName, ExecutionOptions executionOptions, Object[] parameters)
at System.Data.Entity.Core.Objects.ObjectContext.<>c__DisplayClass65`1.b__64()
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func`1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectContext.<>c__DisplayClass65`1.b__63()
at System.Data.Entity.SqlServer.DefaultSqlExecutionStrategy.Execute[TResult](Func`1 operation)
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteStoreQueryReliably[TElement](String commandText, String entitySetName, ExecutionOptions executionOptions, Object[] parameters)
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteStoreQuery[TElement](String commandText, ExecutionOptions executionOptions, Object[] parameters)
at System.Data.Entity.Internal.LazyEnumerator`1.MoveNext()
at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
at System.Linq.Enumerable.ToList[TSource](IEnumerable`1 source)
at Nop.Data.NopObjectContext.ExecuteStoredProcedureList[TEntity](String commandText, Object[] parameters)
at Nop.Services.Catalog.ProductService.SearchProducts(IList`1& filterableSpecificationAttributeOptionIds, Boolean loadFilterableSpecificationAttributeOptionIds, Int32 pageIndex, Int32 pageSize, IList`1 categoryIds, Int32 manufacturerId, Int32 storeId, Int32 vendorId, Int32 warehouseId, Nullable`1 productType, Boolean visibleIndividuallyOnly, Boolean markedAsNewOnly, Nullable`1 featuredProducts, Nullable`1 priceMin, Nullable`1 priceMax, Int32 productTagId, String keywords, Boolean searchDescriptions, Boolean searchManufacturerPartNumber, Boolean searchSku, Boolean searchProductTags, Int32 languageId, IList`1 filteredSpecs, ProductSortingEnum orderBy, Boolean showHidden, Nullable`1 overridePublished)
at Nop.Services.Catalog.ProductService.SearchProducts(Int32 pageIndex, Int32 pageSize, IList`1 categoryIds, Int32 manufacturerId, Int32 storeId, Int32 vendorId, Int32 warehouseId, Nullable`1 productType, Boolean visibleIndividuallyOnly, Boolean markedAsNewOnly, Nullable`1 featuredProducts, Nullable`1 priceMin, Nullable`1 priceMax, Int32 productTagId, String keywords, Boolean searchDescriptions, Boolean searchManufacturerPartNumber, Boolean searchSku, Boolean searchProductTags, Int32 languageId, IList`1 filteredSpecs, ProductSortingEnum orderBy, Boolean showHidden, Nullable`1 overridePublished)
at Nop.Web.Controllers.CatalogController.SearchTermAutoComplete(String term)
at lambda_method(Closure , ControllerBase , Object[] )
at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.b__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState)
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.b__3d()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass46.b__3f()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.<>c__DisplayClass2b.b__1c()
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.b__1e(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState)
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult)
at System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult)
at System.Web.Mvc.MvcHandler.b__5(IAsyncRes
Request information:
https://store.DOMAIN.local:443/catalog/searchtermautocomplete?term=test
Request path: /catalog/searchtermautocomplete
User host address: 192.168.144.126
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\store.DOMAIN.local
Thread information:
Thread ID: 5
Is impersonating: False
Stack trace: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Web.Mvc.MvcHandler.b__5(IAsyncResult asyncResult, ProcessRequestState innerState)
at System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
If you go to the Administration section and then to Configuration then Settings and then to All settings and search in the Name field at the top of the screen for commonsettings.usestoredproceduresifsupported
Make sure it is set to False
If you need to, click edit and type False over True and try running your search again.
Copy the website folder to a new location and recreate the website in IIS (delete the old bindings) and point the new website to the new folder and the web.config file should maintain all of the custom setting including database connection etc.
This may well solve the issue if it is bad data held within the ASP log files pertaining to this site.
