Batch converting CSV to TXT Tab Delimited removing Speech Marks
Preparation for Import to Monsoon StoneEdge from Linnworks
We had an issue where Linnworks has changed from the desktop install to the Linnworks.net solution and had ceased to provide TXT tab delimited files as an option and so we had a look at some online solutions for converting files.
This was found to be a good option - you just drop the vbs file into the folder with the VSC files and it converts all of the files present into tab delimited TXT files without quote/speech marks.
CSV to TXT batch conversion vbs
The script was from someone called Jojo Yee- Maestro di Search on techsupportalert.com
We just altered the file types to suit this example.
