We are seeing the following on a machine recently upgraded from Windows 7 Pro to Windows 10 Pro:
Source: ESENT
Date: 31/05/2019 09:23:59
Event ID: 455
Task Category: Logging/Recovery
Computer: Desktop-PC1.domain.local
StartMenuExperienceHost (9540,R,98) TILEREPOSITORYS-1-5-21-SSID: Error -1023 (0xfffffc01) occurred while opening logfile C:\Users\user\AppData\Local\TileDataLayer\Database\EDB.log.
455
844
9540,R,98
TILEREPOSITORYS-1-5-21-643322192-3791837119-3815354684-500:
-1023 (0xfffffc01)
The machine appears to have lost all of the MS Office configuration for the user - Outlook and Access need to be configured again...?
All of the following appeared in quick sucession in the event log after the upgrade completed:
Source: Microsoft-Windows-User Profiles Service
Date: 30/05/2019 14:02:13
Event ID: 1534
Keywords:
User: domain\user
Profile notification of event Upgrade for component {SSID} failed, error code is See Tracelogging for error details.
1534
0x8000000000000000
657
Upgrade
{SSID}
Source: ESENT
Date: 30/05/2019 14:03:20
Event ID: 643
Task Category: Table/Column/Index Definition
taskhostw (4252,D,50) WebCacheLocal: Out of date NLS sort version detected on the database 'C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat' for Locale 'en-US', index sort version: (SortId=00000000-0000-0000-0000-000000000000, Version=0006010100060101), current sort version: (SortId=00000001-57ee-1e5c-00b4-d0000bb1e11e, Version=0006020F0006020F).
643
658
taskhostw
4252,D,50
WebCacheLocal:
en-US
0006010100060101
0006020F0006020F
Source: ESENT
Event ID: 614
taskhostw (4252,D,50) WebCacheLocal: Database 'C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat': The secondary index 'PartitionIdIndex' of table 'Containers' is out of date with sorting libraries. If used in this state (i.e. not rebuilt), it may appear corrupt or get further corrupted. If there is no later event showing the index being rebuilt, then please defragment the database to rebuild the index.
614
659
taskhostw
4252,D,50
WebCacheLocal:
PartitionIdIndex
Containers
Source: ESENT
Date: 30/05/2019 14:03:29
Event ID: 522
Task Category: General
StartMenuExperienceHost (5604,P,98) TILEREPOSITORYS-1-5-21-643322192-3791837119-3815354684-2149: An attempt to open the device with name "\\.\C:" containing "C:\" failed with system error 5 (0x00000005): "Access is denied. ". The operation will fail with error -1032 (0xfffffbf8).
522
660
5604,P,98
\\.\C:
C:\
-1032 (0xfffffbf8)
5 (0x00000005)
Access is denied.
Source: ESENT
Event ID: 455
StartMenuExperienceHost (5604,R,98) TILEREPOSITORYS-1-5-21-643322192-3791837119-3815354684-2149: Error -1023 (0xfffffc01) occurred while opening logfile C:\Users\user\AppData\Local\TileDataLayer\Database\EDB.log.
455
661
5604,R,98
-1023 (0xfffffc01)
Source: ESENT
Date: 30/05/2019 14:03:54
Event ID: 640
taskhostw (4252,D,50) WebCacheLocal: Error -1919 validating header page on flush map file "C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.jfm". The flush map file will be invalidated.
Additional information: [SignDbHdrFromDb:Create time:05/30/2019 13:03:53.715 Rand:53030417 Computer:] [SignFmHdrFromDb:Create time:05/30/2019 13:03:53.668 Rand:1701537027 Computer:] [SignDbHdrFromFm:Create time:05/30/2019 13:03:20.871 Rand:2850974935 Computer:] [SignFmHdrFromFm:Create time:05/30/2019 13:03:20.996 Rand:761013594 Computer:]
640
1
662
taskhostw
4252,D,50
WebCacheLocal:
-1919
Source: ESENT
Event ID: 636
taskhostw (4252,D,50) WebCacheLocal: Flush map file "C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.jfm" will be deleted. Reason: ReadHdrFailed.
636
1
663
taskhostw
4252,D,50
WebCacheLocal:
ReadHdrFailed
Source: Application Error
Date: 30/05/2019 14:06:52
Event ID: 1000
Task Category: (100)
Faulting application name: backgroundTaskHost.exe, version: 10.0.18362.1, time stamp: 0x533f8404
Faulting module name: KERNELBASE.dll, version: 10.0.18362.145, time stamp: 0xef881ca4
Exception code: 0x00000004
Fault offset: 0x000000000003a839
Faulting process id: 0x1834
Faulting application start time: 0x01d516e889ca93ab
Faulting application path: C:\WINDOWS\system32\backgroundTaskHost.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: b6ac4a82-2277-4af9-af0e-4f7dbfb5862a
Faulting package full name: Microsoft.WindowsStore_11811.1001.18.0_x64__8wekyb3d8bbwe
Faulting package-relative application ID: App
1000
665
10.0.18362.1
533f8404
KERNELBASE.dll
10.0.18362.145
ef881ca4
00000004
000000000003a839
1834
01d516e889ca93ab
App
Source: Microsoft-Windows-Winlogon
Date: 30/05/2019 14:12:35
Event ID: 6005
The winlogon notification subscriber is taking long time to handle the notification event (Logoff).
6005
682
Profiles
Logoff
8603FE7F
Date: 30/05/2019 14:12:54
Event ID: 6006
The winlogon notification subscriber took 79 second(s) to handle the notification event (Logoff).
6006
683
Profiles
79
Logoff
00000000
This appears to be an issue with the Windows 10 TILE system database after an in-line upgrade from Windows 7.
Given that the database was not present before Windows 8, this is a new database on this system.
It appears that the user has somehow inherited a corrupted Tile database and we are recreating some users on the PC to see if we can get a clean Tile DB to resolve the issue.
We actually found that this disappeared when another user logged in from the domain - it was just the local user that had been upgraded that suffered permission problems writing to it's own local log files etc.
A newly created local user was also found not to inherit these errors.
