I have some of the following:
Foundry GBIC SFP 1000MBps Modules
Prolabs GBIC SFP 1000MBps Modules
If I plug them into a Netgear GS748TS and run an LC cable from the in port to the out port on the same module, I get activity, on either Prolabs or Foundry.
If I run a cable from one Netgear switch to another with two of the same modules from in to out and vice-versa, I get nothing
If I run a cable from two modules the same on the same switch, I get nothing
Even though the first test proves that the Netgear can see activity from the module.
Can anyone explain this? Do I have to use a Netgear module? I did not have to use a Netgear module to connect my DrayTek Vigor 3900 to my Netgear GS748TS which is exactly the same switch.
What is the problem?
Thanks,
argo
  • argo
  • 50.8% (Neutral)
  • Newbie
We are having the same issue with some modules we bought off of eBay that were allegedly proper Netgear modules but they have no manufacturer label on them. We get no link light or connectivity/activity light and so no traffic - does anyhone know what else we can try. Have tried multiple switches etc. but to no avail!!!
