Offline drdread
#1 Posted : 13 October 2021 14:09:08(UTC)
Australia
Was thanked: 3 time(s) in 3 post(s)
Macbook 2013
An error occurred while preparing the installation. Try running this application again
Have cleared disk
Online...
No luck Think
or PayPal with This Link
Offline drdread
#2 Posted : 13 October 2021 14:14:05(UTC)
Australia
It was the time on the machine, I had to run ntpdate -u time.apple.com whilst online.
Offline drdread
#3 Posted : 13 October 2021 14:45:18(UTC)
Australia
OK so then I got an error about no packages being available and got stuck in an El Capitan install loop.
My friend told me that setting the time top today was a mistake and that I should use the following command to set a date in 2017:
I used terminal and typed: date -u {month}{day}{hour}{minute}{year} but replacing each variable with a two figure number, in this case: date 0101000017
I did this mid install loop and after a reboot it installed as expected. Applause
Trustpilot
