Offline kateawaits
#1 Posted : 14 July 2021 12:37:54(UTC)
kateawaits
What can I do to speed up Outlook opening?
I am on SSDs and we have a fast dedicated internet but I cannot get in to Outlook in less than 5-10 minutes.
I have maybe 6 or 7 on-line and on-premises accounts with Exchange 2019 & Office 365
or PayPal with This Link
#2 Posted : 19 October 2021 11:58:43(UTC)
Was thanked: 12 time(s) in 10 post(s)
Reduce the mailbox size and/or the number of accounts you have open.
Check the add-ins you are using under options\add-ins.
Reduce the number of months of downloaded data on the accounts.
Move the data files to a separate disk, preferably an SSD that is not the system disk.
More RAM
More CPU power
Use web mail for some of the accounts if you do not need a lot of features and do not check the mail often.
Offline stevefckay
#3 Posted : 03 November 2021 09:52:28(UTC)
stevefckay
Rank: Member
It was the Dynamics CRM add-in that was causing this issue. I had to move the CRM website into the Intranet zone and change the authentication to used current username and password to get it working.
Trustpilot
