kateawaits
  • kateawaits
  • 72% (Friendly)
On My windows 10 I just removed broadcom network driver software and received a blue screen of death..
driver_overran_stack_buffer BSOD
Then when I rebooted again it started OK.
What did it mean? I don't think it even restarted it just BSOD'd during the process...? 🤔
The buffer overrun limit is designed to stop drivers sucking all the resource out of the system. If the buffer overran then the system shut down as a precaution. If it keeps happening then you should try and locate a newer version of the driver.
