What can we do about this error?
It was the only good DC in the domain as the other one is broken.
Log Name: Directory Service
Source: Microsoft-Windows-ActiveDirectory_DomainService
Date: 10/03/2021 09:51:23
Event ID: 2092
Task Category: Replication
User: ANONYMOUS LOGON
Computer: dc01.domain.local
This server is the owner of the following FSMO role, but does not consider it valid. For the partition which contains the FSMO, this server has not replicated successfully with any of its partners since this server has been restarted. Replication errors are preventing validation of this role.
Operations which require contacting a FSMO operation master will fail until this condition is corrected.
FSMO Role: DC=domain,DC=local
User Action:
1. Initial synchronization is the first early replications done by a system as it is starting. A failure to initially synchronize may explain why a FSMO role cannot be validated. This process is explained in KB article 305476.
2. This server has one or more replication partners, and replication is failing for all of these partners. Use the command repadmin /showrepl to display the replication errors. Correct the error in question. For example there maybe problems with IP connectivity, DNS name resolution, or security authentication that are preventing successful replication.
http://support.microsoft.com .
The following operations may be impacted:
Schema: You will no longer be able to modify the schema for this forest.
Domain Naming: You will no longer be able to add or remove domains from this forest.
PDC: You will no longer be able to perform primary domain controller operations, such as Group Policy updates and password resets for non-Active Directory Domain Services accounts.
RID: You will not be able to allocation new security identifiers for new user accounts, computer accounts or security groups.
Infrastructure: Cross-domain name references, such as universal group memberships, will not be updated properly if their target object is moved or renamed.
<Provider Name="Microsoft-Windows-ActiveDirectory_DomainService" Guid="{0e8478c5-3605-4e8c-8497-1e730c959516}" EventSourceName="NTDS General" />
<EventID Qualifiers="32768">2092</EventID>
<Task>5</Task>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2021-03-10T09:51:23.813750000Z" />
<EventRecordID>16180</EventRecordID>
<Execution ProcessID="584" ThreadID="720" />
<Channel>Directory Service</Channel>
<Computer>dc01.domain.local</Computer>
<Security UserID="S-1-5-7" />
<Data>DC=domain,DC=local</Data>
Edited by moderator
4 months ago
