Joined: 08/01/2017(UTC) Posts: 672  Location: London Thanks: 17 times Was thanked: 6 time(s) in 6 post(s)
How can we solve this issue with Server 2008 R2? We are receiving a message when using OWA on our Exchange 2007 server: Your connection is not fully secure This site uses an outdated security configuration, which may expose your information (for example, passwords, messages, or credit cards) when it is sent to this site. NET::ERR_SSL_OBSOLETE_VERSION Your connection is not fully secure NET::ERR_SSL_OBSOLETE_VERSION Edited by user 16 November 2020 11:44:58(UTC)
| Reason: Not specified |
If you ever wanted to thank us, you can send us Bitcoins using:12G4A52Znm5s35buKDEmKU2p2vQY69Nsyo
Rank: Administration
Groups: Administrators
Was thanked: 16 time(s) in 15 post(s)
It should be as simple as the following:
Click the start button
Type Regedit
Right click the Regedit icon presented and choose 'Run as administrator'
In the left hand pane, browse down to: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols
Create two new keys, which resemble folders in Windows Explorer, called TLS 1.1 and TLS 1.2
In each key, create the following DWORD 32 bit values called:
DisabledByDefault Set the value to 0
Enabled Set the value to 1
Press Windows Button + R and enter IISReset into the Run box and press enter.
Important Information:
The Windows Server Forum uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
