#1 Posted : 01 October 2020 19:14:26(UTC)
All VM machines on hyper-v host dropping every other ping
system slow on 2012 R2 Hyper-V over dual fibre LACP Intel 10G 2P X520 NIC
Seeing the following two every second:
Log Name: System
Source: Microsoft-Windows-MsLbfoSysEvtProvider
Date: 01/10/2020 18:34:40
Event ID: 16945
Computer: server.domain.local
MAC conflict: A port on the virtual switch has the same MAC as one of the underlying team members on Team Nic Microsoft Network Adapter Multiplexor Driver #2
<Provider Name="Microsoft-Windows-MsLbfoSysEvtProvider" Guid="{387ed463-8b1b-42c9-9ef0-803fdfd5d94e}" EventSourceName="MsLbfoProvider" />
<EventID Qualifiers="32768">16945</EventID>
<TimeCreated SystemTime="2020-10-01T17:34:40.462221100Z" />
<EventRecordID>150148</EventRecordID>
<Execution ProcessID="4" ThreadID="8096" />
<Channel>System</Channel>
<Computer>server.domain.local</Computer>
<Data Name="DriverObject">
<Data Name="Member">Microsoft Network Adapter Multiplexor Driver #2</Data>
Log Name: System
Date: 01/10/2020 18:34:41
Event ID: 16949
Member Nic {36bc0193-ef3f-4e2d-baad-a6ade2abc522} Disconnected.
<EventID Qualifiers="32768">16949</EventID>
<TimeCreated SystemTime="2020-10-01T17:34:41.466981800Z" />
<EventRecordID>150149</EventRecordID>
<Execution ProcessID="4" ThreadID="1104" />
<Data Name="Member">{36bc0193-ef3f-4e2d-baad-a6ade2abc522}</Data>
Have gone back to an unteamed copper cable in the meantime...
Edited by user 01 October 2020 19:18:13(UTC)  | Reason: Not specified
or PayPal with This Link
Offline kateawaits
#2 Posted : 21 July 2021 16:49:36(UTC)
kateawaits
Have you checked the settings on the switch? We had this issue on fibre cards teamed to a DrayTek switch on LACP and we had to set the ports timeout settings to be short before they worked properly or reliably.
The duplication of ARP settings is part of the way that the hyper-v server routes the traffic through it's own card and into the VM just like you have to set with some firewalls, such as the old Checkpoint systems.
Edited by user 21 July 2021 16:51:03(UTC)  | Reason: Not specified
Trustpilot
