What does this mean?
Source: ASP.NET 4.0.30319.0
Date: 06/09/2020 16:09:19
Event ID: 1309
Task Category: Web Event
Computer: Satie.domain.local
Event code: 3003
Event message: A validation error has occurred.
Event time: 06/09/2020 16:09:19
Event time (UTC): 06/09/2020 15:09:19
Event ID: d7075c5848ca466f9bae3d9d614c8a0a
Event sequence: 7
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/33/ROOT-1-132438775749167667
Trust level: Full
Application Virtual Path: /
Application Path: E:\Websites\www\website\
Machine name: SATIE
Process information:
Process ID: 17000
Process name: w3wp.exe
Account name: IIS APPPOOL\website
Exception information:
Exception type: HttpRequestValidationException
Exception message: A potentially dangerous Request.Form value was detected from the client (messagetext="
at System.Web.HttpRequest.ValidateString(String value, String collectionKey, RequestValidationSource requestCollection)
at System.Web.HttpValueCollection.EnsureKeyValidated(String key)
at System.Web.HttpValueCollection.Get(String name)
at System.Web.UI.WebControls.TextBox.LoadPostData(String postDataKey, NameValueCollection postCollection)
at System.Web.UI.Page.ProcessPostData(NameValueCollection postData, Boolean fBeforeLoad)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.contact_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Request information:
https://www.domain.local:443/contact.aspx
Request path: /contact.aspx
User host address: 134.249.124.67
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\website
Thread information:
Thread ID: 63
Is impersonating: False
Stack trace: at System.Web.HttpRequest.ValidateString(String value, String collectionKey, RequestValidationSource requestCollection)
Custom event details:
1309
2335067
Satie.domain.local
3003
06/09/2020 16:09:19
06/09/2020 15:09:19
Full
SATIE
17000
w3wp.exe
IIS APPPOOL\website
<a href=https://anti...").
/contact.aspx
134.249.124.67
False
IIS APPPOOL\website
63
IIS APPPOOL\website
False
This is an error with the website you are browsing failing to send an email from the contacts page.
Send the error to the website administrator.
