Is this an issue with Windows backup? I didn't think I was actually backing this PC up...
Source: Microsoft-Windows-Defrag
Date: 8/23/2020 3:48:14 PM
Event ID: 264
Computer: computer.domain.local
The storage optimizer couldn't complete retrim on System (C:) because: The operation requested is not supported by the hardware backing the volume. (0x8900002A)
264
30348
retrim
Backup (C:)
2A000089800200008D0000009000000022B63823DBB1BD381B0700000000000000000000
The system is trying to perform optimisation which are probably handled by the disk itself. If it is an SSD then it doesn’t matter.
If it is a newer disk ignore this also. If it is older, it should probably be replaced anyhow before it fails.
