Windows Server Forum
Windows Desktop
Windows 10
Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface.
Joined: 08/01/2017(UTC) Posts: 711  Location: London Thanks: 19 times Was thanked: 6 time(s) in 6 post(s)
VSS issue on my Windows 10 box: Log Name: Application Source: VSS Date: 7/9/2020 3:53:22 PM Event ID: 8194 Task Category: None Level: Error Keywords: Classic User: N/A Computer: %computername%.domain Description: Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied. . This is often caused by incorrect security settings in either the writer or requestor process. Operation: Gathering Writer Data Context: Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220} Writer Name: System Writer Writer Instance ID: {39dafbf4-7be0-41d9-930c-1514502b2469} Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="VSS" /> <EventID Qualifiers="0">8194</EventID> <Version>0</Version> <Level>2</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2020-07-09T14:53:22.2572092Z" /> <EventRecordID>22674</EventRecordID> <Correlation /> <Execution ProcessID="0" ThreadID="0" /> <Channel>Application</Channel> <Computer>%computername%.domain</Computer> <Security /> </System> <EventData> <Data>0x80070005, Access is denied. </Data> <Data> Operation: Gathering Writer Data Context: Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220} Writer Name: System Writer Writer Instance ID: {39dafbf4-7be0-41d9-930c-1514502b2469}</Data> <Binary>2D20436F64653A20575254575254494330303030313238372D2043616C6C3A20575254575254494330303030313234312D205049443A202030303030343238342D205449443A202030303030343833362D20434D443A2020433A5C57494E444F57535C73797374656D33325C737663686F73742E657865202D6B204E6574776F726B53657276696365202D70202D732043727970745376632D20557365723A204E616D653A204E5420415554484F524954595C4E4554574F524B20534552564943452C205349443A532D312D352D3230</Binary> </EventData> </Event> What setting do you think is wrong, if that is what the issue is? Edited by user 21 September 2020 14:59:56(UTC)
| Reason: Thanks for that. |
If you ever wanted to thank us, you can send us Bitcoins using:12G4A52Znm5s35buKDEmKU2p2vQY69Nsyo
Joined: 26/08/2020(UTC) Posts: 76  Thanks: 9 times Was thanked: 3 time(s) in 3 post(s)
This is a COM+ permissions problem. If you go into component services from the start search and expand the computers section on the left, right click on the My Computer icon and choose propertiesClick the COM Security Tab:  Now under Access Permissions click the Edit default button. Click add:  Now enter Network Service and press OK Make sure the user is given all permissions:  Press OK and Restart the PC
 1 user thanked drdread for this useful post.
Windows Desktop
Windows 10
Important Information:
The Windows Server Forum uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
