#1 Posted : 09 July 2020 23:09:05(UTC)
VSS issue on my Windows 10 box:
Source: VSS
Date: 7/9/2020 3:53:22 PM
Event ID: 8194
Computer: %computername%.domain
Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied.
. This is often caused by incorrect security settings in either the writer or requestor process.
Operation:
Gathering Writer Data
Context:
Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220}
Writer Name: System Writer
Writer Instance ID: {39dafbf4-7be0-41d9-930c-1514502b2469}
<Provider Name="VSS" />
<EventID Qualifiers="0">8194</EventID>
<TimeCreated SystemTime="2020-07-09T14:53:22.2572092Z" />
<EventRecordID>22674</EventRecordID>
<Computer>%computername%.domain</Computer>
<Data>0x80070005, Access is denied.
<Data>
Operation:
Context:
Writer Instance ID: {39dafbf4-7be0-41d9-930c-1514502b2469}</Data>
<Binary>2D20436F64653A20575254575254494330303030313238372D2043616C6C3A20575254575254494330303030313234312D205049443A202030303030343238342D205449443A202030303030343833362D20434D443A2020433A5C57494E444F57535C73797374656D33325C737663686F73742E657865202D6B204E6574776F726B53657276696365202D70202D732043727970745376632D20557365723A204E616D653A204E5420415554484F524954595C4E4554574F524B20534552564943452C205349443A532D312D352D3230</Binary>
What setting do you think is wrong, if that is what the issue is?
Edited by user 21 September 2020 14:59:56(UTC)  | Reason: Thanks for that.
or PayPal with This Link
Offline drdread
#2 Posted : 21 September 2020 14:25:20(UTC)
Australia
Was thanked: 3 time(s) in 3 post(s)
This is a COM+ permissions problem.
If you go into component services from the start search and expand the computers section on the left, right click on the My Computer icon and choose properties
Click the COM Security Tab:
Now under Access Permissions click the Edit default button.
Click add:
Click the Edit Default button
Now enter Network Service and press OK
Make sure the user is given all permissions:
Add Network Service
Press OK and Restart the PC
thanks 1 user thanked drdread for this useful post.
Lemonde on 21/09/2020(UTC)
Trustpilot
