If you cannot boot up following this error then you can try a few things.
The issue can be related to either the
winlogon.exe file or the
csrss.exe file being of the wrong version, being in use or being corrupted.
It can also be a driver or other software error.
The first thing we should do is try and repair our disk and check for errors. Download bootable Windows Media from here:
download bootable Windows media Now once you have downloaded the above software, make a bootable USB or DVD.
Now boot into your PC using the media when asked to 'choose an option' choose
troubleshoot and then select
advanced optionsSelect
Command PromptType
BCDEdit and look for the
OSDevice property, this will tell you the drive letter which contains your Windows folder - may be D:
In the command prompt box, type
chkdsk D: /f /r where
D: is the driver letter you just got above, and press
EnterAllow the disk check to complete.
Now run '
SFC /scannow /offbootdir=D:\ /offwindir=D:\windows' in the same box, remembering once more to substitute the appropriate drive letter and see what results you get. This process should restore all of the system files to their proper conditions.
Next, in that same box again, run
dism /image:D:\Windows /cleanup-image /restorehealth making sure you use the correct drive letter discovered above once more.
Which will restore all of the file drivers etc. to their proper states. If the process completes try staring Windows normally.
The file versions should now be matched and the system should start but if not, try entering the boot media again and under
troubleshoot>advanced options try running
start-up repair
Edited by user
