Hello all,
Just a quick note to say that, after downloading my GoDaddy certificate, which is a wildcard certificate, I was running into trouble. I had successfully run the 'complete certificate request' wizard and imported my certificate into IIS, but when I tried to bind it to any of my websites I recevied a message:
a specified logon session does not exist 0x80070520
And something about that it may have been terminated.
Now this binding does apply to several websites on the server, such the wildcard, but this error was confusing as everything appeared to have worked correctly.
I tried this a couple of times and every time got the same error. I could see that the private key was being loaded but somehow it was not as expected.
Because I had to load it onto another server I exported it as a PFX file and tried to load it onto the other server and it worked fine.
I then tried to import the PFX file onto the original server and it worked fine too.
I think that the format of the CRT file upset IIS8 or the PEM part of the certificate was not agreeing with the rest of it, but either way that PFX file loads into all of the servers no problem so I just used that :)
Ta-ta for now
