#1 Posted : 26 September 2019 10:35:58(UTC)
Trying to restore to a Hyper-V VM -
The system restore failed.
Error details: The processor architecture or OS version of Windows Recovery Environment is not the same as that of the computer that was backed up. For example, a backup of an Vista X64-based computer can be recovered only by using an Vista X64-based version of Windows Recovery
Now I know this isn't true as I use Windows 10 Ent to recover pretty much anything, but here it is being fussy - what can I do?
Can I identify the Windows type from the backup files?
#2 Posted : 26 September 2019 11:00:58(UTC)
I just double-clicked the system drive under the WindowsBackup folder and checked %SYSTEMDRIVE%\Windows\System32\License.rtf and go the version.
This enabled me to restore the system without issue using the correct ISO.
Perhaps it is more fussy than I remember :|
