I am seeing this error on my Windows 10 Pro machine
This is my usual home office machine and so it is put through the milling machine daily :)
Source: MSCRMTracing
Date: 25/10/2018 16:38:06
Event ID: 17203
Computer: %COMPUTERNAME%.domain.net
Invalid Trace Directory. Additional Info:[ Invalid Trace Directory (Reporting Process:Trace Diretory is Null. TraceSettings: {Filename: ,FileCountSuffix:1 ,TraceFileSize:10485760 ,TraceDirectory:C:\Users\%username%\AppData\Local\Microsoft\MSCRM\Traces ,TracingCallStack:No ,IsTracingOff:Unset ,LoadState:LoadSuccessfulUnreported ,RefreshTraceInt:-1 ,SiteWideRefreshTraceInt:-1 ,RegistryRefreshTraceInt:-1 ,Precedence:Default} ] , AppDomain:IEXPLORE)
17203
5823
IEXPLORE
C:\Program Files (x86)\Internet Explorer\
Is this yet another CRM issue with Windows 10?
I can go to C:\Users\%username%\AppData\Local\Microsoft\MSCRM\Traces in explorer with no issues logged in as me but there are no files present.
I have write permissions - I have checked - and it is within my profile anyway.
What would the problem be?
