Offline andrewt2m
#1 Posted : 11 January 2022 17:20:32(UTC)
SharePoint server 2016 search crawl error:
The content processing pipeline failed to process the item. ( ExpandSegments; ; SearchID = D04AFF02-00E2-4DB9-8170-517BBD00980F )
Fails to search every item since a certain update or something...?
Should I reset the index do you think?
or PayPal with This Link
Offline andrewt2m
#2 Posted : 11 January 2022 20:50:19(UTC)
Reset content search database to no avail
Offline andrewt2m
#3 Posted : 11 January 2022 22:31:12(UTC)
re-running the farm configuration wizard may be a solution as we have applied service packs to the SQL server and it may need to be re-aligned as suggested in expert sex change.
Edited by user 12 January 2022 13:43:27(UTC)  | Reason: Not specified
Offline andrewt2m
#4 Posted : 12 January 2022 13:31:23(UTC)
We are going to try and recreate the search app just using the GUI run as admin.
Highlight search application.
click delete
Await completion.
Run farm configuration - it will tick the Search Application box.
Proceed.
Await completion.
Await the content sources to be populated.
Run a full crawl - voila!
Edited by user 12 January 2022 16:33:50(UTC)  | Reason: Not specified
Trustpilot
