What is this because of - I am trying to install Sage v27 over the network using a network source for the files - is that related to the restrictions imposed here?
Log Name: System
Source: Tcpip
Date: 31/01/2021 19:12:38
Event ID: 4230
Computer: PC.domain.local
TCP/IP has chosen to restrict the congestion window for several connections due to a network condition. This could be related to a problem in the TCP global or supplemental configuration and will cause degraded throughput.
4230
1306414
System
PC.domain.local
00000000010000000000000086100080000000000000000000000000000000000000000000000000
If you have the latest drivers for your NICs then I would ignore this unless you are seeing a problem.
