Windows Server Forum
Hardware and Devices
Hardware Issues
idrac virtual console the network connection has been dropped
Joined: 08/01/2017(UTC) Posts: 711  Location: London Thanks: 19 times Was thanked: 6 time(s) in 6 post(s)
What do I need to do as this is urgent? |
If you ever wanted to thank us, you can send us Bitcoins using:12G4A52Znm5s35buKDEmKU2p2vQY69Nsyo
Rank: Member
OK here is what I did when I faced this situation - I am assuming you are in a similar position, but if not it might at least help someone else. After trying adding the server IP to safe addresses in Java under the security tab I realised I was using Chrome which probably doesn't allow Java at all anymore. I switched to IE as I was using a Windows 2012 Server and the remote virtual console started working fine. I managed to make the changes and could go to sleep  Edited by user 07 April 2021 09:53:30(UTC)
| Reason: Not specified
Hardware Issues
Important Information:
The Windows Server Forum uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
