Joined: 08/01/2017(UTC) Posts: 693  Location: London Thanks: 18 times Was thanked: 6 time(s) in 6 post(s)
This is connected to my last post: Cannot use USB disk with a Hyper-V VM This is the error when the VM is already running and I try and add the disk Host 2016 VM 2016 Adding the device 'Microsoft:Hyper-V:Physical Disk Drive' to VM Failed  Log Name: Microsoft-Windows-Hyper-V-VMMS-Admin Source: Microsoft-Windows-Hyper-V-VMMS Date: 23/02/2021 14:20:27 Event ID: 14140 Task Category: None Level: Error Keywords: User: SYSTEM Computer: host.domain.local Description: 'VM' failed to add device 'Physical Disk Drive'. (Virtual machine ID CBD00B13-D1DF-4A59-8D3C-0F9CEE14934C) Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Microsoft-Windows-Hyper-V-VMMS" Guid="{6066F867-7CA1-4418-85FD-36E3F9C0600C}" /> <EventID>14140</EventID> <Version>0</Version> <Level>2</Level> <Task>0</Task> <Opcode>0</Opcode> <Keywords>0x8000000000000000</Keywords> <TimeCreated SystemTime="2021-02-23T14:20:27.259479800Z" /> <EventRecordID>1532</EventRecordID> <Correlation /> <Execution ProcessID="2444" ThreadID="8696" /> <Channel>Microsoft-Windows-Hyper-V-VMMS-Admin</Channel> <Computer>host.domain.local</Computer> <Security UserID="S-1-5-18" /> </System> <UserData> <VmlEventLog xmlns="http://www.microsoft.com/Windows/Virtualization/Events"> <VmName>HappyHub</VmName> <VmId>CBD00B13-D1DF-4A59-8D3C-0F9CEE14934C</VmId> <Parameter0>Physical Disk Drive</Parameter0> </VmlEventLog> </UserData> </Event> Edited by user 23 February 2021 15:12:55(UTC)
| Reason: Not specified |
If you ever wanted to thank us, you can send us Bitcoins using:12G4A52Znm5s35buKDEmKU2p2vQY69Nsyo
Ooops It was the wrong disk That one was in use as a backup for something else. |
Important Information:
The Windows Server Forum uses cookies. By continuing to browse this site, you are agreeing to our use of cookies.
More Details
Close
