Is this a firewall issue or a service issue do you think?
Log Name: System
Source: Microsoft-Windows-WinRM
Date: 3/27/2020 4:37:34 PM
Event ID: 10149
Computer: serverVM1.domain.local
The WinRM service is not listening for WS-Management requests.
User Action
If you did not intentionally stop the service, use the following command to see the WinRM configuration:
winrm enumerate winrm/config/listener
10149
9599616388
System
If you follow the command in the event ID, by running it in an elevated command prompt:
You should see something like:
If you do not see the local IP of the server, but only the 127.0.0.1 address then delete the entry with:
netsh http delete iplisten 127.0.0.1
Then run winrm enumerate winrm/config/listener again and see if the local IP is present now.
If the list is blank, run: winrm quickconfig
