This is what I had to do to regain control of my graphics card:
Sourced from Microsoft Answers:
1. Run the following script in powershell using 'run as administrator' privileges:
function enable-privilege
{ param(
http://msdn.microsoft.com/en-us/library/bb530716 (VS.85).aspx
[ValidateSet(
"SeAssignPrimaryTokenPrivilege", "SeAuditPrivilege", "SeBackupPrivilege", "SeChangeNotifyPrivilege", "SeCreateGlobalPrivilege",
"SeCreatePagefilePrivilege", "SeCreatePermanentPrivilege", "SeCreateSymbolicLinkPrivilege", "SeCreateTokenPrivilege",
"SeDebugPrivilege", "SeEnableDelegationPrivilege", "SeImpersonatePrivilege", "SeIncreaseBasePriorityPrivilege",
"SeIncreaseQuotaPrivilege", "SeIncreaseWorkingSetPrivilege", "SeLoadDriverPrivilege", "SeLockMemoryPrivilege",
"SeMachineAccountPrivilege", "SeManageVolumePrivilege", "SeProfileSingleProcessPrivilege", "SeRelabelPrivilege",
"SeRemoteShutdownPrivilege", "SeRestorePrivilege", "SeSecurityPrivilege", "SeShutdownPrivilege", "SeSyncAgentPrivilege",
"SeSystemEnvironmentPrivilege", "SeSystemProfilePrivilege", "SeSystemtimePrivilege", "SeTakeOwnershipPrivilege", "SeTcbPrivilege",
"SeTimeZonePrivilege", "SeTrustedCredManAccessPrivilege", "SeUndockPrivilege", "SeUnsolicitedInputPrivilege")]
$Privilege,
## The process on which to adjust the privilege. Defaults to the current process.
$ProcessId = $pid,
## Switch to disable the privilege, rather than enable it.
[Switch] $Disable
## Taken from P/Invoke.NET with minor adjustments.
$definition = @'
using System;
using System.Runtime.InteropServices;
public class AdjPriv
[DllImport("advapi32.dll", ExactSpelling = true, SetLastError = true)]
internal static extern bool AdjustTokenPrivileges(IntPtr htok, bool disall,
ref TokPriv1Luid newst, int len, IntPtr prev, IntPtr relen);
internal static extern bool OpenProcessToken(IntPtr h, int acc, ref IntPtr phtok);
[DllImport("advapi32.dll", SetLastError = true)]
internal static extern bool LookupPrivilegeValue(string host, string name, ref long pluid);
[StructLayout(LayoutKind.Sequential, Pack = 1)]
internal struct TokPriv1Luid
public int Count;
public long Luid;
public int Attr;
internal const int SE_PRIVILEGE_ENABLED = 0x00000002;
internal const int SE_PRIVILEGE_DISABLED = 0x00000000;
internal const int TOKEN_QUERY = 0x00000008;
internal const int TOKEN_ADJUST_PRIVILEGES = 0x00000020;
public static bool EnablePrivilege(long processHandle, string privilege, bool disable)
bool retVal;
TokPriv1Luid tp;
IntPtr hproc = new IntPtr(processHandle);
IntPtr htok = IntPtr.Zero;
retVal = OpenProcessToken(hproc, TOKEN_ADJUST_PRIVILEGES | TOKEN_QUERY, ref htok);
tp.Count = 1;
tp.Luid = 0;
if(disable)
tp.Attr = SE_PRIVILEGE_DISABLED;
else
tp.Attr = SE_PRIVILEGE_ENABLED;
retVal = LookupPrivilegeValue(null, privilege, ref tp.Luid);
retVal = AdjustTokenPrivileges(htok, false, ref tp, 0, IntPtr.Zero, IntPtr.Zero);
return retVal;
$processHandle = (Get-Process -id $ProcessId).Handle
$type = Add-Type $definition -PassThru
$type[0]::EnablePrivilege($processHandle, $Privilege, $Disable)
function Takeown-Registry($key)
{ switch ($key.split('\')[0])
{ "HKEY_CLASSES_ROOT"
{ $reg = [Microsoft.Win32.Registry]::ClassesRoot
$key = $key.substring(18)
"HKEY_CURRENT_USER"
{ $reg = [Microsoft.Win32.Registry]::CurrentUser
"HKEY_LOCAL_MACHINE"
{ $reg = [Microsoft.Win32.Registry]::LocalMachine
$key = $key.substring(19)
# take ownership
$key = $reg.OpenSubKey($key, "ReadWriteSubTree", "TakeOwnership")
$owner = [Security.Principal.NTAccount]"Administrators"
$acl = $key.GetAccessControl()
$acl.SetOwner($owner)
$key.SetAccessControl($acl)
# set FullControl
$rule = New-Object System.Security.AccessControl.RegistryAccessRule("Administrators", "FullControl", "Allow")
$acl.SetAccessRule($rule)
# reset owner
$owner = [Security.Principal.NTAccount]"NT SERVICE\TrustedInstaller"
# Grant authority to registry key
Write-Host; Write-Host "Elevating privileges for this process" -f yellow; Write-Host
do {$result = enable-privilege SeTakeOwnershipPrivilege }
until ($result -eq $true)
do {$result = enable-privilege SeRestorePrivilege }
$key="HKEY_CLASSES_ROOT\AppID\{4839DDB7-58C2-48F5-8283-E1D1807D0D7D}"
Write-Host "Granting authority to $key"
$key="HKEY_CLASSES_ROOT\CLSID\{6B3B8D23-FA8D-40B9-8DBD-B950333E2C52}"
Write-Host; Write-Host "Done"; Write-Host
2. Open Regedit to this key: Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\WMI\Autologger\
Open
Event Viewer and find the 10016 error
Open the event and click the
Detail Tab
Click the
+System in friendly view &
copy the GUID numberGo back to Regedit and press
[CTRL] + F and search for the GUID number
Set the
enabled key to Zero 0
Now I can use the GPU again.
Edited by user
