#1 Posted : 14 April 2020 13:06:20(UTC)
This was on a Windows 2012 R2 with WebRoot
Your PC ran into a problem and needs to restart
We're just collecting some information, and then we'll restart for you
If you'd like to know more, you can search online for this error: 0xc000021a
ANy ideas? I was trying to restart the Oracle database XNE onboard at the time...
Offline AuFestival
#2 Posted : 03 July 2020 16:26:47(UTC)
AuFestival
Rank: Newbie
Croatia
I am seeing this too...
d'oh!
Offline sirclesadmin
#3 Posted : 15 July 2020 11:03:10(UTC)
Rank: Administration
Groups: Administrators
Was thanked: 9 time(s) in 9 post(s)
If you cannot boot up following this error then you can try a few things.
The issue can be related to either the winlogon.exe file or the csrss.exe file being of the wrong version, being in use or being corrupted.
It can also be a driver or other software error.
The first thing we should do is try and repair our disk and check for errors. Download bootable Windows Media from here:download bootable Windows media
Now once you have downloaded the above software, make a bootbale USB or DVD.
Now boot into your PC from the media when asked to 'choose an option' choose troubleshoot and then select advanced options
Select Command Prompt
Type BCDEdit and lookf or the OSDevice property, this will tell you the drive letter which contains your Windows folder - may be D:
In the command prompt box, type chkdsk D: /f /r where D: is the driver letter you just got above, and press Enter
Allow the disk check to complete.
Now run 'SFC /scannow /offbootdir=D:\ /offwindir=D:\windows' in the same box, remembering once more to substitute the appropriate drive letter and see what results you get. This process should restore all of the system files to their proper conditions.
Next, in that same box again, run dism /image:D:\Windows /cleanup-image /restorehealth making sure you use the correct driver letter discovered above again.
Which will restore all of the file drivers etc. to their proper states. If the process completes try staring Windows normally.
The file versions should now be matched and the system should start but if not, try entering the boot media again and under troubleshoot>advanced options try running start-up repair
Edited by user 15 July 2020 11:45:38(UTC)  | Reason: Not specified
thanks 1 user thanked sirclesadmin for this useful post.
Lemonde on 27/07/2020(UTC)
