VSS issue on my Windows 10 box:
Source: VSS
Date: 7/9/2020 3:53:22 PM
Event ID: 8194
Computer: %computername%.domain
Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied.
. This is often caused by incorrect security settings in either the writer or requestor process.
Operation:
Gathering Writer Data
Context:
Writer Class Id: {e8132975-6f93-4464-a53e-1050253ae220}
Writer Name: System Writer
Writer Instance ID: {39dafbf4-7be0-41d9-930c-1514502b2469}
8194
22674
Operation:
Context:
2D20436F64653A20575254575254494330303030313238372D2043616C6C3A20575254575254494330303030313234312D205049443A202030303030343238342D205449443A202030303030343833362D20434D443A2020433A5C57494E444F57535C73797374656D33325C737663686F73742E657865202D6B204E6574776F726B53657276696365202D70202D732043727970745376632D20557365723A204E616D653A204E5420415554484F524954595C4E4554574F524B20534552564943452C205349443A532D312D352D3230
What setting do you think is wrong, if that is what the issue is?
Edited by user
Reason: Thanks for that.
