Windows 7 Issue - according to Microsoft there was an issue with the ISO but this is a factory installed Toshiba Laptop?
Source: Microsoft-Windows-WMI
Date: 17/06/2020 08:33:19
Event ID: 10
Computer: %computername%
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
10
4310
%computername%
//./root/CIMV2
0x80041003
Can I just ignore this or should I follow the steps here:
https://support.microsoft.com/en-gb/help/2545227/event-id-10-is-logged-in-the-application-log-after-you-install-service
Well that workaround appears to suppress the error, so if the error itself bothers you, then it is rather pointless.
If it is just the event log that perplexes you, then that workaround will solve it.
