#1 Posted : 28 April 2020 12:29:10(UTC)
I am seeing this error on CRM tracing on a Windows 10 Pro client:
Source: MSCRMTracing
Date: 4/27/2020 4:50:12 PM
Event ID: 17203
Invalid Trace Directory. Additional Info:[ Invalid Trace Directory (Reporting Process:Trace Diretory is Null. TraceSettings: {Filename: ,FileCountSuffix:1 ,TraceFileSize:10485760 ,TraceDirectory:C:\Users\%username%\AppData\Local\Microsoft\MSCRM\Traces ,TracingCallStack:No ,IsTracingOff:Unset ,LoadState:LoadSuccessfulUnreported ,RefreshTraceInt:-1 ,SiteWideRefreshTraceInt:-1 ,RegistryRefreshTraceInt:-1 ,Precedence:Default} ] , AppDomain:IEXPLORE)
<Provider Name="MSCRMTracing" />
<EventID Qualifiers="49152">17203</EventID>
<TimeCreated SystemTime="2020-04-27T15:50:12.3791667Z" />
<EventRecordID>11783</EventRecordID>
<Computer>%computername%.domain.local</Computer>
<Data>[ Invalid Trace Directory</Data>
<Data>Trace Diretory is Null. TraceSettings: {Filename: ,FileCountSuffix:1 ,TraceFileSize:10485760 ,TraceDirectory:C:\Users\%username%\AppData\Local\Microsoft\MSCRM\Traces ,TracingCallStack:No ,IsTracingOff:Unset ,LoadState:LoadSuccessfulUnreported ,RefreshTraceInt:-1 ,SiteWideRefreshTraceInt:-1 ,RegistryRefreshTraceInt:-1 ,Precedence:Default} ] </Data>
<Data>IEXPLORE</Data>
<Data>C:\Program Files (x86)\Internet Explorer\</Data>
I have not seen any obvious errors on this workstation, it displays the CRM client OK in Outlook 2019
or PayPal with This Link
Trustpilot
