We are seeing that the server is still referencing the old OAB server even though it has been decommissioned. Where do we remove the reference?
Source: MSExchange Front End HTTP Proxy
Date: 12/07/2017 07:00:30
Event ID: 3005
Task Category: Core
Computer: server.domain,suffix
[Oab] Marking ClientAccess 2010 server OABserver.domain,suffix (https://OABserver.domain,suffix/OAB) as unhealthy due to exception: System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.144.14:443
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
--- End of inner exception stack trace ---
at System.Net.HttpWebRequest.GetResponse()
at Microsoft.Exchange.HttpProxy.ProtocolPingStrategyBase.Ping(Uri url)
<Provider Name="MSExchange Front End HTTP Proxy" />
<EventID Qualifiers="32768">3005</EventID>
<Task>1</Task>
<TimeCreated SystemTime="2017-07-12T06:00:30.000000000Z" />
<EventRecordID>3998681</EventRecordID>
<Computer>server.domain,suffix</Computer>
<Data>Oab</Data>
<Data>OABserver.domain,suffix</Data>
<Data>https://OABserver.domain,suffix/OAB</Data>
<Data>System.Net.WebException: Unable to connect to the remote server ---&gt; System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.144.14:443
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket&amp; socket, IPAddress&amp; address, ConnectSocketState state, IAsyncResult asyncResult, Exception&amp; exception)
at Microsoft.Exchange.HttpProxy.ProtocolPingStrategyBase.Ping(Uri url)</Data>
Also seeing:
Source: MSExchangeApplicationLogic
Date: 31/08/2017 10:56:31
Event ID: 3054
Task Category: Extension
Computer: servername.domain.suffix
Scenario: ProcessOrgExtensions. The organization mailbox for emaildomain.suffix could not be retrieved.
<Provider Name="MSExchangeApplicationLogic" />
<EventID Qualifiers="49156">3054</EventID>
<Task>3</Task>
<TimeCreated SystemTime="2017-08-31T09:56:31.000000000Z" />
<EventRecordID>4564150</EventRecordID>
<Computer>servername.domain.suffix</Computer>
<Data>ProcessOrgExtensions</Data>
<Data>emaildomain.suffix</Data>
Check that all of the old servers have been removed in ADSIEdit
Under services>microsoft exchange>Organisation name>Administrative Groups>Exchange administrative group>servers
Just be sure you do not delete any servers that are live, so check version numbers etc before taking any action.
DO NOT DELETE THE WRONG SERVER, YOU HAVE BEEN WARNED!!!
Because then you will have to restore an authoritative domain restore onto a DC to get email working again.
