#1 Posted : 31 May 2019 09:35:17(UTC)
We are seeing the following on a machine recently upgraded from Windows 7 Pro to Windows 10 Pro:
Source: ESENT
Date: 31/05/2019 09:23:59
Event ID: 455
Task Category: Logging/Recovery
Computer: Desktop-PC1.domain.local
StartMenuExperienceHost (9540,R,98) TILEREPOSITORYS-1-5-21-SSID: Error -1023 (0xfffffc01) occurred while opening logfile C:\Users\user\AppData\Local\TileDataLayer\Database\EDB.log.
<Provider Name="ESENT" />
<EventID Qualifiers="0">455</EventID>
<Task>3</Task>
<TimeCreated SystemTime="2019-05-31T08:23:59.129043500Z" />
<EventRecordID>844</EventRecordID>
<Computer>Desktop-PC1.domain.local</Computer>
<Data>StartMenuExperienceHost</Data>
<Data>9540,R,98</Data>
<Data>TILEREPOSITORYS-1-5-21-643322192-3791837119-3815354684-500: </Data>
<Data>C:\Users\user\AppData\Local\TileDataLayer\Database\EDB.log</Data>
<Data>-1023 (0xfffffc01)</Data>
The machine appears to have lost all of the MS Office configuration for the user - Outlook and Access need to be configured again...?
#2 Posted : 31 May 2019 09:42:21(UTC)
All of the following appeared in quick sucession in the event log after the upgrade completed:
Source: Microsoft-Windows-User Profiles Service
Date: 30/05/2019 14:02:13
Event ID: 1534
Keywords:
User: domain\user
Profile notification of event Upgrade for component {SSID} failed, error code is See Tracelogging for error details.
<Provider Name="Microsoft-Windows-User Profiles Service" Guid="{89b1e9f0-5aff-44a6-9b44-0a07a7ce5845}" />
<EventID>1534</EventID>
<TimeCreated SystemTime="2019-05-30T13:02:13.027295300Z" />
<EventRecordID>657</EventRecordID>
<Execution ProcessID="1996" ThreadID="4368" />
<Security UserID="S-1-5-21-643322192-3791837119-3815354684-2149" />
<EventData Name="EVENT_PROFILE_NOTIFICATION_FAIL">
<Data Name="Event">Upgrade</Data>
<Data Name="Component">{SSID}</Data>
<Data Name="Error">See Tracelogging for error details</Data>
Source: ESENT
Date: 30/05/2019 14:03:20
Event ID: 643
Task Category: Table/Column/Index Definition
taskhostw (4252,D,50) WebCacheLocal: Out of date NLS sort version detected on the database 'C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat' for Locale 'en-US', index sort version: (SortId=00000000-0000-0000-0000-000000000000, Version=0006010100060101), current sort version: (SortId=00000001-57ee-1e5c-00b4-d0000bb1e11e, Version=0006020F0006020F).
<EventID Qualifiers="0">643</EventID>
<Task>5</Task>
<TimeCreated SystemTime="2019-05-30T13:03:20.918593000Z" />
<EventRecordID>658</EventRecordID>
<Data>taskhostw</Data>
<Data>4252,D,50</Data>
<Data>WebCacheLocal: </Data>
<Data>C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat</Data>
<Data>en-US</Data>
<Data>00000000-0000-0000-0000-000000000000</Data>
<Data>0006010100060101</Data>
<Data>00000001-57ee-1e5c-00b4-d0000bb1e11e</Data>
<Data>0006020F0006020F</Data>
Source: ESENT
Event ID: 614
taskhostw (4252,D,50) WebCacheLocal: Database 'C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.dat': The secondary index 'PartitionIdIndex' of table 'Containers' is out of date with sorting libraries. If used in this state (i.e. not rebuilt), it may appear corrupt or get further corrupted. If there is no later event showing the index being rebuilt, then please defragment the database to rebuild the index.
<EventID Qualifiers="0">614</EventID>
<Task>5</Task>
<EventRecordID>659</EventRecordID>
<Data>PartitionIdIndex</Data>
<Data>Containers</Data>
Source: ESENT
Date: 30/05/2019 14:03:29
Event ID: 522
Task Category: General
StartMenuExperienceHost (5604,P,98) TILEREPOSITORYS-1-5-21-643322192-3791837119-3815354684-2149: An attempt to open the device with name "\\.\C:" containing "C:\" failed with system error 5 (0x00000005): "Access is denied. ". The operation will fail with error -1032 (0xfffffbf8).
<EventID Qualifiers="0">522</EventID>
<Task>1</Task>
<TimeCreated SystemTime="2019-05-30T13:03:29.246787600Z" />
<EventRecordID>660</EventRecordID>
<Data>5604,P,98</Data>
<Data>TILEREPOSITORYS-1-5-21-643322192-3791837119-3815354684-2149: </Data>
<Data>\\.\C:</Data>
<Data>C:\</Data>
<Data>-1032 (0xfffffbf8)</Data>
<Data>5 (0x00000005)</Data>
<Data>Access is denied. </Data>
Source: ESENT
Event ID: 455
StartMenuExperienceHost (5604,R,98) TILEREPOSITORYS-1-5-21-643322192-3791837119-3815354684-2149: Error -1023 (0xfffffc01) occurred while opening logfile C:\Users\user\AppData\Local\TileDataLayer\Database\EDB.log.
<Task>3</Task>
<EventRecordID>661</EventRecordID>
<Data>5604,R,98</Data>
Source: ESENT
Date: 30/05/2019 14:03:54
Event ID: 640
taskhostw (4252,D,50) WebCacheLocal: Error -1919 validating header page on flush map file "C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.jfm". The flush map file will be invalidated.
Additional information: [SignDbHdrFromDb:Create time:05/30/2019 13:03:53.715 Rand:53030417 Computer:] [SignFmHdrFromDb:Create time:05/30/2019 13:03:53.668 Rand:1701537027 Computer:] [SignDbHdrFromFm:Create time:05/30/2019 13:03:20.871 Rand:2850974935 Computer:] [SignFmHdrFromFm:Create time:05/30/2019 13:03:20.996 Rand:761013594 Computer:]
<EventID Qualifiers="0">640</EventID>
<Task>1</Task>
<TimeCreated SystemTime="2019-05-30T13:03:54.043556200Z" />
<EventRecordID>662</EventRecordID>
<Data>-1919</Data>
<Data>C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.jfm</Data>
<Data>[SignDbHdrFromDb:Create time:05/30/2019 13:03:53.715 Rand:53030417 Computer:] [SignFmHdrFromDb:Create time:05/30/2019 13:03:53.668 Rand:1701537027 Computer:] [SignDbHdrFromFm:Create time:05/30/2019 13:03:20.871 Rand:2850974935 Computer:] [SignFmHdrFromFm:Create time:05/30/2019 13:03:20.996 Rand:761013594 Computer:]</Data>
Source: ESENT
Event ID: 636
taskhostw (4252,D,50) WebCacheLocal: Flush map file "C:\Users\user\AppData\Local\Microsoft\Windows\WebCache\WebCacheV01.jfm" will be deleted. Reason: ReadHdrFailed.
<EventID Qualifiers="0">636</EventID>
<Task>1</Task>
<EventRecordID>663</EventRecordID>
<Data>ReadHdrFailed</Data>
Source: Application Error
Date: 30/05/2019 14:06:52
Event ID: 1000
Task Category: (100)
Faulting application name: backgroundTaskHost.exe, version: 10.0.18362.1, time stamp: 0x533f8404
Faulting module name: KERNELBASE.dll, version: 10.0.18362.145, time stamp: 0xef881ca4
Exception code: 0x00000004
Fault offset: 0x000000000003a839
Faulting process id: 0x1834
Faulting application start time: 0x01d516e889ca93ab
Faulting application path: C:\WINDOWS\system32\backgroundTaskHost.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: b6ac4a82-2277-4af9-af0e-4f7dbfb5862a
Faulting package full name: Microsoft.WindowsStore_11811.1001.18.0_x64__8wekyb3d8bbwe
Faulting package-relative application ID: App
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Task>100</Task>
<TimeCreated SystemTime="2019-05-30T13:06:52.492848700Z" />
<EventRecordID>665</EventRecordID>
<Data>backgroundTaskHost.exe</Data>
<Data>10.0.18362.1</Data>
<Data>533f8404</Data>
<Data>KERNELBASE.dll</Data>
<Data>10.0.18362.145</Data>
<Data>ef881ca4</Data>
<Data>00000004</Data>
<Data>000000000003a839</Data>
<Data>1834</Data>
<Data>01d516e889ca93ab</Data>
<Data>C:\WINDOWS\system32\backgroundTaskHost.exe</Data>
<Data>C:\WINDOWS\System32\KERNELBASE.dll</Data>
<Data>b6ac4a82-2277-4af9-af0e-4f7dbfb5862a</Data>
<Data>Microsoft.WindowsStore_11811.1001.18.0_x64__8wekyb3d8bbwe</Data>
<Data>App</Data>
Source: Microsoft-Windows-Winlogon
Date: 30/05/2019 14:12:35
Event ID: 6005
The winlogon notification subscriber <Profiles> is taking long time to handle the notification event (Logoff).
<Provider Name="Microsoft-Windows-Winlogon" Guid="{DBE9B383-7CF3-4331-91CC-A3CB16A3B538}" EventSourceName="Wlclntfy" />
<EventID Qualifiers="32768">6005</EventID>
<TimeCreated SystemTime="2019-05-30T13:12:35.601932100Z" />
<EventRecordID>682</EventRecordID>
<Data>Profiles</Data>
<Data>Logoff</Data>
<Binary>8603FE7F</Binary>
Date: 30/05/2019 14:12:54
Event ID: 6006
The winlogon notification subscriber <Profiles> took 79 second(s) to handle the notification event (Logoff).
<EventID Qualifiers="32768">6006</EventID>
<TimeCreated SystemTime="2019-05-30T13:12:54.725777600Z" />
<EventRecordID>683</EventRecordID>
<Data>79</Data>
<Data>Logoff</Data>
<Binary>00000000</Binary>
#3 Posted : 09 August 2019 11:36:47(UTC)
This appears to be an issue with the Windows 10 TILE system database after an in-line upgrade from Windows 7.
Given that the database was not present before Windows 8, this is a new database on this system.
It appears that the user has somehow inherited a corrupted Tile database and we are recreating some users on the PC to see if we can get a clean Tile DB to resolve the issue.
#4 Posted : 11 September 2019 07:37:05(UTC)
We actually found that this disappeared when another user logged in from the domain - it was just the local user that had been upgraded that suffered permission problems writing to it's own local log files etc.
A newly created local user was also found not to inherit these errors.
