#1 Posted : 19 December 2018 10:33:24(UTC)
Hello,
What is the maximum capacity for an SD card in a WileyFox Spark X please?
#2 Posted : 19 December 2018 12:58:53(UTC)
Just to say that there are two options here:
If you wish to add the SD card seamlessly to your internal storage so that it can be used for apps eetc. then there is a maximum of 32GB
If you just wish to use the SD card for storage then the maximum is definitely higher - I am using a 128GB card in my phone currently without problems.
