#1 Posted : 18 October 2018 10:13:16(UTC)
In Monsoon StoneEdge (Microsoft Access) we are seeing the following error:
Visual Basic Runtime Error 3012, Object 'IVAQ1' already exists:
Monsoon StoneEdge Reporting Error
So the query still exists in the DB?
I know that this query normally gets removed but the report must have been interrupted before it could delete the query so now we need to remove it manually...
How do we manually remove a temporary query from Microsoft Access Database
Our Monsoon StoneEdge runs in Microsoft SQL by the way.
Edited by user 18 October 2018 10:21:01(UTC)  | Reason: Not specified
#2 Posted : 18 October 2019 11:05:05(UTC)
This value should actually be deleted on completion of the report, but if it is not then you can manually delete by opening the Microsoft Access design view and deleting the IVAQ1 object from the database and running the report again.
You can enter design mode by holding down the SHIFT key when you double click the icon to open Stone Edge.
Edited by moderator 05 November 2019 12:59:27(UTC)  | Reason: Not specified
