#1 Posted : 11 May 2018 11:20:47(UTC)
I am seeing this on a website that has been moved to a different folder on an IIS server:
Source: ASP.NET 4.0.30319.0
Date: 11/05/2018 12:13:36
Event ID: 1310
Task Category: Web Event
Computer: %COMPUTERNAME%.domain.suffix
Event code: 3008
Event message: A configuration error has occurred.
Event time: 11/05/2018 12:13:36
Event time (UTC): 11/05/2018 11:13:36
Event ID: 4fd8f4a189fe42b0990906e4a1098174
Event sequence: 34
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/55/ROOT-1-131705103475489943
Trust level: Full
Application Virtual Path: /
Application Path: E:\Websites\www\websiteNAME\
Machine name: %COMPUTERNAME%
Process information:
Process ID: 10860
Process name: w3wp.exe
Account name: IIS APPPOOL\websiteNAME
Exception information:
Exception type: ConfigurationErrorsException
Exception message: It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (E:\Websites\www\websiteNAME\gtme-forum\web.config line 29)
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object& result, Object& resultRuntimeObject)
at System.Configuration.BaseConfigurationRecord.GetSection(String configKey)
at System.Web.Configuration.RuntimeConfig.GetSectionObject(String sectionName)
at System.Web.Configuration.RuntimeConfig.GetSection(String sectionName, Type type, ResultsIndex index)
at System.Web.Configuration.RuntimeConfig.get_Identity()
at System.Web.HttpContext.SetImpersonationEnabled()
at System.Web.HttpApplication.AssignContext(HttpContext context)
at System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context)
Request information:
Request URL: http://personaltraine.rs/GTME-forum/
Request path: /GTME-forum/
User host address: 83.244.231.200
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\websiteNAME
Thread information:
Thread ID: 54
Is impersonating: False
Stack trace: at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
Custom event details:
<Provider Name="ASP.NET 4.0.30319.0" />
<EventID Qualifiers="32768">1310</EventID>
<Task>3</Task>
<TimeCreated SystemTime="2018-05-11T11:13:36.000000000Z" />
<EventRecordID>2202997</EventRecordID>
<Computer>%COMPUTERNAME%.domain.suffix</Computer>
<Data>3008</Data>
<Data>A configuration error has occurred.</Data>
<Data>11/05/2018 12:13:36</Data>
<Data>11/05/2018 11:13:36</Data>
<Data>4fd8f4a189fe42b0990906e4a1098174</Data>
<Data>34</Data>
<Data>1</Data>
<Data>0</Data>
<Data>/LM/W3SVC/55/ROOT-1-131705103475489943</Data>
<Data>Full</Data>
<Data>/</Data>
<Data>E:\Websites\www\websiteNAME\</Data>
<Data>%COMPUTERNAME%</Data>
<Data>
<Data>10860</Data>
<Data>w3wp.exe</Data>
<Data>IIS APPPOOL\websiteNAME</Data>
<Data>ConfigurationErrorsException</Data>
<Data>It is an error to use a section registered as allowDefinition='MachineToApplication' beyond application level. This error can be caused by a virtual directory not being configured as an application in IIS. (E:\Websites\www\websiteNAME\gtme-forum\web.config line 29)
at System.Configuration.BaseConfigurationRecord.GetSectionRecursive(String configKey, Boolean getLkg, Boolean checkPermission, Boolean getRuntimeObject, Boolean requestIsHere, Object&amp; result, Object&amp; resultRuntimeObject)
<Data>http://personaltraine.rs/GTME-forum/</Data>
<Data>/GTME-forum/</Data>
<Data>83.244.231.200</Data>
<Data>
<Data>False</Data>
<Data>
<Data>54</Data>
<Data>False</Data>
<Data> at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
Edited by user 11 May 2018 11:41:02(UTC)  | Reason: Not specified
#2 Posted : 11 May 2018 11:39:04(UTC)
This was an error with the old web.config file - the quick solution was to delete the application and recreate in the correct app pool.
