Source: ASP.NET 2.0.50727.0
Date: 21/08/2017 09:50:18
Event ID: 1309
Task Category: Web Event
Computer: server.domain.suffix
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 21/08/2017 09:50:18
Event time (UTC): 21/08/2017 08:50:18
Event ID: 1615293d13e6436c806c805b0155fc99
Event sequence: 3
Event occurrence: 1
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/52/ROOT-1-131477790117528150
Trust level: Full
Application Virtual Path: /
Application Path: drive\websitepath
Machine name: server
Process information:
Process ID: 37744
Process name: w3wp.exe
Account name: IIS APPPOOL\.NET v2.0 Classic
Exception information:
Exception type: SqlException
Exception message: Failed to generate a user instance of SQL Server due to a failure in reading registry keys. The connection will be closed.
Request information:
http://www.recruitmentcompanies.co.uk/default.aspx
Request path: /default.aspx
User host address: 81.152.255.98
User:
Is authenticated: False
Authentication Type:
Thread account name: IIS APPPOOL\.NET v2.0 Classic
Thread information:
Thread ID: 3
Is impersonating: False
Stack trace: at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)
at System.Data.SqlClient.TdsParser.Run(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj)
at System.Data.SqlClient.SqlInternalConnectionTds.CompleteLogin(Boolean enlistOK)
at System.Data.SqlClient.SqlInternalConnectionTds.AttemptOneLogin(ServerInfo serverInfo, String newPassword, Boolean ignoreSniOpenTimeout, Int64 timerExpire, SqlConnection owningObject, Boolean withFailover)
at System.Data.SqlClient.SqlInternalConnectionTds.LoginNoFailover(String host, String newPassword, Boolean redirectedUserInstance, SqlConnection owningObject, SqlConnectionString connectionOptions, Int64 timerStart)
at System.Data.SqlClient.SqlInternalConnectionTds.OpenLoginEnlist(SqlConnection owningObject, SqlConnectionString connectionOptions, String newPassword, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlInternalConnectionTds..ctor(DbConnectionPoolIdentity identity, SqlConnectionString connectionOptions, Object providerInfo, String newPassword, SqlConnection owningObject, Boolean redirectedUserInstance)
at System.Data.SqlClient.SqlConnectionFactory.CreateConnection(DbConnectionOptions options, Object poolGroupProviderInfo, DbConnectionPool pool, DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionFactory.CreatePooledConnection(DbConnection owningConnection, DbConnectionPool pool, DbConnectionOptions options)
at System.Data.ProviderBase.DbConnectionPool.CreateObject(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.UserCreateRequest(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionPool.GetConnection(DbConnection owningObject)
at System.Data.ProviderBase.DbConnectionFactory.GetConnection(DbConnection owningConnection)
at System.Data.ProviderBase.DbConnectionClosed.OpenConnection(DbConnection outerConnection, DbConnectionFactory connectionFactory)
at System.Data.SqlClient.SqlConnection.Open()
at JobSiteStarterKit.DAL.DBAccess.Open() in drive\websitepathApp_Code\DAL\DBAccess.vb:line 181
at JobSiteStarterKit.DAL.DBAccess.ExecuteScalar() in drive\websitepathApp_Code\DAL\DBAccess.vb:line 63
at JobSiteStarterKit.DAL.DBAccess.ExecuteScalar(String commandtext) in drive\websitepathApp_Code\DAL\DBAccess.vb:line 77
at JobSiteStarterKit.BOL.Company.GetCompanyCount() in drive\websitepathApp_Code\BOL\Company.vb:line 262
at Statistics.Page_Load(Object sender, EventArgs e) in drive\websitepathUserControls\Statistics.ascx.vb:line 7
at System.Web.UI.Control.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
1309
2088237
3005
21/08/2017 09:50:18
21/08/2017 08:50:18
1
Full
drive\websitepath
server
37744
w3wp.exe
SqlException
/default.aspx
81.152.255.98
False
False
