Hyper-V Replication error issue on SQL server VM:
Log Name: Microsoft-Windows-Hyper-V-VMMS-Admin
Source: Microsoft-Windows-Hyper-V-VMMS
Date: 16/03/2020 11:37:28
Event ID: 32022
Keywords:
User: SYSTEM
Hyper-V could not replicate changes for virtual machine 'DB VM': The operation timed out (0x00002EE2). (Virtual machine ID 106925A8-DA68-4D41-8293-0014FE5A27AD)
<Provider Name="Microsoft-Windows-Hyper-V-VMMS" Guid="{6066F867-7CA1-4418-85FD-36E3F9C0600C}" />
<EventID>32022</EventID>
<TimeCreated SystemTime="2020-03-16T11:37:28.556143900Z" />
<EventRecordID>119513</EventRecordID>
<Execution ProcessID="3044" ThreadID="4280" />
<Channel>Microsoft-Windows-Hyper-V-VMMS-Admin</Channel>
<Computer>%computername%.domain.local</Computer>
<UserData>
<VmlEventLog xmlns="http://www.microsoft.com/Windows/Virtualization/Events">
<VmName>DB VM</VmName>
<VmId>106925A8-DA68-4D41-8293-0014FE5A27AD</VmId>
<ErrorMessage>%%12002</ErrorMessage>
<ErrorCode>0x00002EE2</ErrorCode>
</VmlEventLog>
</UserData>
Coincides with:
Event ID: 29312
Keywords:
User: SYSTEM
Connection to the Replica server '%computername%.domain.local' timed out while waiting to receive a response for virtual machine DB VM: The operation timed out(0x00002EE2). The total size of replication data being transferred is 332 KByte(s). (Virtual machine ID 106925A8-DA68-4D41-8293-0014FE5A27AD)
<EventID>29312</EventID>
<TimeCreated SystemTime="2020-03-16T11:37:28.547782000Z" />
<EventRecordID>119512</EventRecordID>
<UserData>
<Parameter0>%computername%.domain.local</Parameter0>
<Parameter1>332</Parameter1>
</VmlEventLog>
</UserData>
And:
Event ID: 32315
Keywords:
User: SYSTEM
Hyper-V failed to replicate changes for virtual machine 'DB VM' (Virtual machine ID 106925A8-DA68-4D41-8293-0014FE5A27AD). Hyper-V will retry replication after 1 minute(s).
<EventID>32315</EventID>
<TimeCreated SystemTime="2020-03-16T11:37:28.556335000Z" />
<EventRecordID>119514</EventRecordID>
<UserData>
<Parameter0>1</Parameter0>
</VmlEventLog>
</UserData>
Is this because the SQL server has too great a disk usage to replicate reliably?
It is worth removing the replication partner and re-adding it as we have solved this error in the past that way.
You will want to look at how many VMs are on that drive and what the throughput it. Have a look at performance monitor on disks and NICs for the servers on each side of the replication.
You will also want to check how much data is being replicated but in the above it only appears to be 332Kbytes but if it is an SQL server there may be issues replicating the whole DB? instead of just part of the file.
It may be worth considering replicating the DB rather than the db drive but it might not suit your needs.
In general, a dedicated disk for the DBs and logs is bets so VMs aren't usually the best idea for SQL.
