We seem to be seeing a lot of the following three event logs and I wanted to ask if this is just the switch being overloaded or some sort of hardware fault or perhaps even a Windows bug:
Log Name: System
Source: iScsiPrt
Date: 28/11/2018 12:06:48
Event ID: 20
Computer: %ComputerName%.Domain.suffix
Connection to the target was lost. The initiator will attempt to retry the connection.
20
1299060
System
\Device\RaidPort2
000060000100000000000000140000C0000000000000000000000000000000000000000000000000690071006E002E0031003900390034002D00310031002E0063006F006D002E006E006500740067006500610072003A006200610063006B00750070006E00610073003A00340038003200360035006500640033003A006900700076006D003000
Log Name: System
Source: iScsiPrt
Event ID: 7
The initiator could not send an iSCSI PDU. Error status is given in the dump data.
1299061
System
\Device\RaidPort2
000064000100000000000000070000C0000000000000000000000000000000000000000000000000410200C0690071006E002E0031003900390034002D00310031002E0063006F006D002E006E006500740067006500610072003A006200610063006B00750070006E00610073003A00340038003200360035006500640033003A006900700076006D003000
Log Name: System
Source: iScsiPrt
Event ID: 34
Level: Information
A connection to the target was lost, but Initiator successfully reconnected to the target. Dump data contains the target name.
34
1299062
System
\Device\RaidPort2
00006000010000000000000022000040000000000000000000000000000000000000000000000000690071006E002E0031003900390034002D00310031002E0063006F006D002E006E006500740067006500610072003A006200610063006B00750070006E00610073003A00340038003200360035006500640033003A006900700076006D003000
Everything resolves itself after this but as we keep data on iSCSI a lot it is a concern...
